Hardware error 0502 lexmark x5100 - Office Equipment & Supplies
  • 1 more comment
  • jkingribeiro Aug 12, 2008
    como corrijo el eroor de hardware 0502 mi maquina es Lexmark 5150
  • Anonymous Aug 16, 2008
    all in one X5100 displays : hardware error 0502
    What does this mean and what is to be done
  • saint6220 Jan 11, 2009
    i cannot seem to fix the hardware error:0502. How do I go about fixing this problem and what is the error identifying?
Lexmark X5100 Hardware error0502
Posted on Oct 06, 2008
Oh for young minds!
Grandson cleaned the bar and the messy ink holders and VOILA!!!!
Has worked since then
My Lexmark x5100 keeps giving error code 0502
After months of use, your printer might get the habit of stopping in the middle of a page and showing "Hardware Error 0502" on the LCD display. If you leave the printer alone for a while, it might start printing again. Then again, it might not. Pretty annoying.
The Lexmark support site will let you power off, remove the power cord for 30 seconds, take out the cartridges and fiddle with some encoder strip. This whole procedure might take you up to 30 minutes and it will not help (been there, done that).
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
Clean it with a paper towel. The towel will be black from ink residue, but you will be able to print again.
Oct 08, 2010 | Lexmark X5150 All-In-One InkJet Printer
Hardware error 0502?
Error 0502 can either be caused by a faulty cartridge or the encoder strip. Here's an article on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. Just click on this link: http://bit.ly/b6uHJp. This should guide you on what to do when having this error. If error continues after following all the steps, don't hesitate to contact Lexmark technical support to further investigate the problem. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark X6170 All-In-One InkJet Printer
Showing Hardware Error 0502
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Feb 07, 2010 | Office Equipment & Supplies
MY Lexmark X5150 All-In-One InkJet Printer displays the message: HARDWARE ERROR 0502
Unfortunately this appears to be a hardware failure and the printer is out of warranty. It is likely that the parts, repair and replacement fees would be more expensive than the actual cost of a new printer at this point.
May 11, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X160 is not printing at all or receiving Faxes. The error that keeps coming up is Hardware Error 0502. Please Advise.
ok sir pls see the link this is the helpfull for the error 0502 in lexmark x160 all in one inkjet printer...ok
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Hardware error 0502
The encoder strip may have gone out of range of the sensor, or it might be dirty.
  2. Disconnect the power cable from the back of the Lexmark X5100/X6100 Series.
  11. Try to print....
Good luck...
Dec 15, 2008 | Lexmark X6170 All-In-One InkJet Printer
Cant receive a fax
HI try this its from the lexmark web site
Nov 21, 2008 | Lexmark X6170 All-In-One InkJet Printer
1,063 people viewed this question
jasbo
jasbo
