Question about Sony KDF46E2000 46" Projection HDTV
I just changed the lamp bulb and now the power is red and flushing what can it be
  • 40 Answers
Did you remember to reset the lamp timer?
Posted on Mar 13, 2011
Mine is doing the same thing, but I replaced the lamp, plugged it back in and turned the power on. It starts to power, does nothing and flashes 3 times. Luckily my old bulb still has a little life so I plugged it back in. Is it as easy as resetting the timer????
Posted on Nov 29, 2011
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Replaced the lamp on a hitachi 50V720, single lamp bulb is flashing red...how do you reset the new bulb?
Hi,no reset, Just make sure the Box (Lamp Enclosure) is pushed in firmly on both sides, left and right. Left side to hit the power connection and Right side to hit the little relay switch, Must be flush against that back side.
it happened to me and I was kicking myself in the ***, a entire weekend went by with a brand new lamp sitting in the enclosure but not completely set in correctly with a flashing red light.
Also get the outside lamp cover in just right where it touches the sensor and sits flush. That's what helped for me.
Good luck.
May 28, 2011 | Hitachi 50V720 Television
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
My Sanyo PLC XE31 wouldn't switch on, bulb replacemetn lamp was lit. Changed bulb and now it switches on, green light shows, fans run, and then after approx 30 seconds the red light flashes and it switches...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jan 24, 2011 | Sanyo FOR PLC-XE31
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
The power will not turn on and the power LED is flashing red.
PT-50LD54 is an LCD rear projection TV with a consumable bulb that wears out normally after 2-5 years of use.
Most likely you need a bulb. That is first step in any troubleshooting for that tv. Check out Panasonic Gallery to identify lamp and replacement bulb.
Changing bulb involves removing the lamp assembly and replacing the bulb in the lamp assembly. Like doing a puzzle. Requires philips screwdriver, pliers and patience. Don't have jam on your fingers when you do it.
easyab
Apr 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Hitachi Model #50V720 50 '
ther is only one lamp bulb to change.
see your users manual to change it.
Jan 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Changed bulb, still no pic
According to the manual the second lamp is indicating that the lamp cover is not closed
Jul 15, 2008 | Zenith E44W46LCD 44" Rear Projection...
Sony KDF46E2000 46" Projection HDTV Logo
262 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
