Question about Canon PowerShot SX100 IS Digital Camera
OBJECT ERROR RESTART CAMERA - Canon PowerShot SX100 IS Digital Camera
    Scholar:
  • 70 Answers
If you did not obstruct the lens, would think there is a battery problem. Digital cameras require lots of power. As you call on it to do more things like extending the lens and focusing the power requirement goes up.
I had a similar problem with my camera and finally discovered that the problem was with the battery to camera electrical connections. I cleaned the contacts as described in the source link about two months ago and have not had a problem since.
The following excerpts came from the source link. Hope this helps!
Most cameras will reset to original settings if batteries are removed for at least one minute. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
The secret to making digital cameras work better is having good electrical contacts between the batteries and the camera.
Digital cameras require lots of power. If electrical contacts are not really good, this can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD display is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. With bad contacts, cameras do strange things like making bad pictures or shutting off with the lens out.
To prevent overcharge, use an automatic two or more hour battery charger with safety timer, temperature monitor and trickle charge technology ($9.78). For longer life, NiMH batteries should be charged often and kept in active use. To preserve battery charge, use the view finder and not the LCD display when possible. Maximum capacity is reached after 2 to 4 charge/discharge cycles.
http://www.google.com/base/a/4210404/D13...
Posted on Mar 14, 2011
2 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: my camera shows an error that says: error restart
Your camera most likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 04, 2010
Kodak easyhare software won't download invalid calling object
just click the red button "share" on your camera, then disable sharing, if you have the device connected to a computer, automatically it will open the content of your camera as if were a pendrive or an external hdd, problem solved.No need of kodak addon software.
Jun 14, 2013 | Cameras
MY Sony cyber shot DSC W35 camera's shutter is open and close repeatedly and asks for power off and restart but nothing is happening. PL advise
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera, press the RESET button located inside the Jack cover of the Camera using a sharp pointed object like ball pen or paper clip. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Jul 17, 2011 | Sony Cyber-Shot DSC-P52 Digital Camera
Panasonic BL -C30 netcam: unable to send e-mail after being triggered by sensor. error log shows: division 4/code 1
Hi.
Try resetting the camera.
Some of the cameras have a small recessed button on the bottom that can be hit by using a small pointed object (such as a paperclip or pen). Other models have a flap on the side that has a reset and a restart button.
If that does not apply try disconnecting power (and removing battery) from all units connected to the system, including main control unit.
Aug 13, 2010 | Panasonic BL-C30A Network Camera
LENS ERROR, RESTART CAMERA...
CANON IXUS 561
Lens sometimes does not extend and error message 'lens error restart camera' appears when camera is turned on. This does not work without several tries and much button pressing. Problem is not caused by finger(s) in front of lens barrel.
May 20, 2010 | Canon PowerShot A560 Digital Camera
Objective error on the screan
this is a common issue the lens gears are stripped. you have to change them out. hope this helps
Aug 20, 2009 | Fuji FinePix F30 Digital Camera
Lens is stuck
You'd need to have it fixed at a service center. For the Canon Powershots as you have, the place that services these models exclusively is: www.camerasandparts.com The Canon Powershots are all they work on and they do excellent work, not expensive at all to have it serviced through them. Hope that helps you with it, good luck.
Aug 15, 2009 | Canon PowerShot A480 Digital Camera
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
My new Canon SX100IS is having "Lens error, Restart Camera" error
It seems the lens assembly has an internal problem and needs to be repaired.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
The reason of it it may be a spring or a metal post located in the focus sub-assembly, but the only way to confirm it is opening the camera and the lens assembly.
Best regards,
Jul 25, 2008 | Canon IXUS V2 Digital Camera
Lens Error, Restart
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Dec 31, 2007 | Cameras
Canon PowerShot SX100 IS Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
