Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
My 1997 ultravision projectionn tv is having yellow shadows.
  • 40 Answers
Best case scenario is your lamp is failing and will need replacing ($200 - $300). Worst case scenario is the panel is starting to fail, meaning it would not be worth repairing. The set is 14 years old and has probably reached its end of life. You can probably replace it for less than a thousand and not only have HDTV but a digital receiver as well.
Posted on Mar 14, 2011
Besides the lamp bulb there is a color wheel inside that may just need to re calibrated usually cost less then 50 bucks at any local tv shop. you can also change your contrast ratio to reduce the yellow coloring
Ultravision Digital TV has shadows and vertical
I believe it is either interference or a convergence issue. To fix an issue with convergence try to find a convergence setting in the menu. If thatr doesn't work try to clean your projection lenses with a q-tip and alcohol.
Good Luck.
Mar 14, 2010 | Televison & Video
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50" Ultravision too much yellow, not much blue
First of all sorry for delay.
can you provide a image of yello shadow.I believe it seems to be technically say "ghost image"
If it is ghost image we can try by entering SERVICE Menu and adjust RGB level of the light engine.
Good luck
Dals123
Oct 04, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi Ulatravision Digital TV....... have a yellow shadow around part of picture
it might be scorch mark starting from the bulbs heat or someone placed a magnet close to machine that gives the same impression
May 09, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 55inch projection tv with blue shadow.
Blue Convergence Ic is defective. let me know if you need to know where to get a replacement IC
May 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Discoloration and shadow in the top left corner
one of the CRTs is going bad...my guess is the green...hard to dignose without a pic...email me a pic of the problem to : harry0000010@yahoo.com and I'll be happy to give you some advice
Jan 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi ultravision digital widescreen
my tv has a magenta pink and green stripe accross the top of screen...is this a bulb problem
Nov 01, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 60 inch ultravision
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 15, 2007 | Televison & Video
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
281 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
