Question about LG WM-2277HW Front Load Washer
...how do I remove the
    Scholar:
  • 106 Answers
When you slide the dispenser drawer all the way out, there is a tab on the top, toward the back, you can sort of pull up on this tab, and then slide the dispenser the rest of the way out. Clean away!
Posted on Mar 14, 2011
Bleach dispenser
Check water flow INTO the dispenser. This happens during the
cycle to dispense the bleach evenly through the load.
Jul 22, 2014 | Frigidaire Washing Machines
The bleach dispebnser looks like it has mildew in it. How do I clean it? The manual says to clean the machine put bleach in the soap dispenser but will that clean the bleach disperser? (I have never used...
Bleach is the only real mildew buster there is. Pour a small amount in that dispenser then wipe it out with a paper towel. Or if its like mine it (the dispenser) will pop out and you can put it in the dishwasher. If you use bleach, you pour in a preset amount before the wash and it will be diluted when the washer fills up.
Dec 25, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Soap dispenser not working properly, the fabric softener and the liquid bleach not dispensing properly. Sometimes the softener dispensed as soon as I push start. The bleach not dispensing at all I have...
Don't know where you live, but commonly silt comes up with the cold water supply, especially in rural areas, and clogs the holes in the dispenser. The best way to deal with this is an old toothbrush to rub it clean. When it dispenses some bits too soon, it could be that the water is pushing through the only holes that are available. Give it a good scrub with an old toothbrush and hopefully you will both be smiling :)
Jun 20, 2017 | Whirlpool Duet GHW9150P Front Load Washer
The bleach dispenser did not dispense bleach during Tub Clean cycle. The drawers were clean (only have had washer 3 wks)
I just called LG and they said for this model WM2101HW the bleach will only dispense from the soap dispenser during the tub clean cycle
Apr 16, 2010 | LG WM2101HW 4.0 cu.ft. Washer
KitchenAid Stylemaster 622784 cleaning the fabric softener dispenser. I can't get the fabric softener apart to clean it. I don't have a manual. I bought it, used, with no manual. Suggestions?
Hi
Thanks for using FixYa. Remove the dispenser and spray with white vinegar. Then spray the agitator with it too. You can pretty much wipe it right out. Vinegar dissolves softener very quickly. The dispenser just wash out with warm water after the vinegar sits on it for a minute, and you hardly have to wipe at it at all. try adding bleach to the dispenser and clean it with a small brush.
The dispenser will pull off from the agitator and you can run hot water in it from the sink. The agitator is not as easy but has a 1/2" bolt holding it to the shaft. remove the bolt and pull up. but you can clean the whole washer with a cup of bleach and that will also clean the agitator. Now run a full tub of hot water and then add a cup of bleach with no soap. After the washer has filled up, then add another gallon of hot water and that will help to rinse out the residues that cause odors. then after that dont use too much soap and you wont have residue build up. Only use the smallest amount of soap that the cup has marked in it.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 07, 2009 | KitchenAid KAWS850L Top Load Washer
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
Sep 13, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
322 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
