Question about Sony HT-6600DP System
My SONY Home Theater Model HT-6600DP unit was working fine and then about tow years after...present, my sub woofer is sounding distorted. Why is this happening? Please help me as I often watch my home movies, its the Best System Ever! Even the radio sounds distorted from the sub woofer. All bass is distorted.
    Brigadier General:
  • 8,546 Answers
Is it so even at lower volumes?
Are you sure it's the sub distorting and not the front or center speakers?
If you designate them incorrectly as Large (which tells the receiver they CAN effectively produce bass frequencies) they will probably distort in the presence of low frequencies.
See Page 17, 19
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-HT-6600DP-Home-Theater-Systems-manual/id/390ag319/t/2/
Posted on Mar 14, 2011
Protect mode constant
doubtful, protect on a sony receiver usually means there is a short in the amp section
Feb 03, 2013 | Sony Ht-6600dp Home Theater In A Box
What is happening to my sub woofer????? D: So I have the sony muteki HT-DDW1600 and have had for the past year. In that time it has served its purpose for many many house parties. Recently I noticed that...
If a fuse blows it won't self-heal when you cycle power.
Swap the subwoofers between the two subwoofer speaker feeds. Maybe it will stay with the channel or maybe it will follow the speaker and make next steps easier.
Jul 20, 2011 | Sony MUTEKI HTDDW1600 Theater System
HI I BOUGHT HT-S6300 3D-Ready Home Theater System 2 DAYS BEFORE. MY SUB-WOOFER IS NOT WORKING. NO SOUND IS COMING OUT EVEN BLUE LIGHT IS ON. I HAVE CHECKED SPEAKER CONFIGURATION, AND IT GIVES SOUND TO ALL...
Check your owners manual.You will probably have to activate the sub woofer outlet,using the remote.This outlet can usually be programmed to do more than one function.
Jun 18, 2011 | Onkyo Audio Players & Recorders
I have a Samsung HT-C550, is there a separate power switch or something for the Sub-woofer? It seems to not have a lot of power.
If it is making any sound at all then it is "on".
Check your subwoofer function and level with Test Tones (page 29) and Auto Sound Calibration (page 30) and don't expect too much from an 8-lb 6.5" subwoofer and a multichannel amp that only draws 75 watts of electricity. Maybe place the sub nearer to a corner.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/search.html?q=Samsung+HT-C550
Mar 23, 2011 | Samsung Ht-c550 5.1 Dvd Home Theater...
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Flashing code s/w chk
It is just that main unit is looking for the "Wireless sub-woofer" and shows this message when it can't find the sub.
wireless connection between main unit and sub should be reset.
Mar 11, 2010 | Samsung HT-X810T Theater System
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
No sound from subwoffer
Check the fuse at the back of the sub it might have blown
May 18, 2009 | Samsung HT-TX72 Theater System
JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
Aug 12, 2008 | JVC TH-M606 System
Sony HT-6600DP System Logo
115 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
