Question about LG 47LX9500 47 3D LED TV with 480 Hz ($349999 before $35000 savings) 47 in 3D HDTVReady
I seem to have a delay between the lips moving and the sound coming out of the tv how can this be fixed
  • 40 Answers
Welcome to Digital TV. Not much you can do about it. Unlike analog video where the A/V was in perfect sync, digital video moves much slowwer that its audio cousin, hence the latency. Save for installing an expensive audio delay device, you will unfortunately just have to get used to it.
Posted on Mar 14, 2011
The sound bar audio does not match up with picture on my tv.what can I do to fix this problem? thanks
Check the menu of the TV (OR the Source like DVD OR Bluray) is there is an option lip-sync. If its there try to adjust the delay with that option.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 25, 2016 | Televison & Video
Lip sync problems
that is a network problem nothing consumer can do about it .
Sep 29, 2015 | Televison & Video
Lip Sink issue, when playing a DVD Lips move & seconds later sound comes out.
Hello your center voice delay is set too high..Go into the audio menu(viewable on the tv) and reset the delay to 0 milliseconds.
Feb 21, 2011 | LG LHT854 Theater System
Just bought a Sharp LED TV and there is a slight delay between hearing sound and seeing lips move. Have cable box hooked up to tv by HDMI and have cable box hooked to AVR (Harmon Kardon AVR125) by optical...
Hi if there is an optical out on the television i would use that direct to your Harmon Kardon AVR 125, the sound would be in sync with picture, as the source is the same.
Jan 31, 2011 | Harman Kardon AVR 125 Receiver
I have a Yamaha RX V800 AV Receiver is their an lip sync adjustment for internally with this amp.
This monster has a lot of built-in opportunities to tune or mis-tune the sound but nothing to deal with the effect you're addressing.
A discussion of lip sync:
http://en.wikipedia.org/wiki/Audio_to_video_synchronization
  • There is extensive use of audio and video signal processing circuitry with significant delays in television systems. Particular video signal processing circuitry which is widely used and contributes significant video delays include frame synchronizers, digital video effects processors, video noise reduction, format converters and MPEG pre-preprocessing.
  • The video monitor processing circuit may delay the video stream. Pixelated displays require video format conversion and deinterlace processing which can add one or more frames of video delay.
  • A video monitor with built-in speakers or line-out may not delay sound and video paths by the same amount of milliseconds. Some video monitors contain internal user-adjustable audio delays to aid in correction of errors.
  • Dec 31, 2010 | Yamaha RX-V800 Receiver
    I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
    When viewing on Digital TV:-
    Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
    Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
    It may result in mismatch of the picture and sound.
    In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
    1. Delay time can be varied in 10msec steps.(0 to 300ms)
    2. Delay time is different between TV Brands.
    So you need to adjust the delay time for correct lip-sync.
    The adjustment is listed in the instruction book page12
    Jun 26, 2010 | JVC TH-G30 Theater System
    Audio: hearing everything twice
    you have a delay time on your home theater JVC, that is normal. So it's either you reduce the delay time of your JVC or do not use the TV sound. Set the delay time of your DSP so you can heqar the sound you wish... like the delay time of your surrond.
    Mar 30, 2008 | Audio Players & Recorders
    Sound/Video delay
    Lip-sync error is a widespread problem caused when video is delayed and audio arrives too soon. Widespread enough that three different manufacturers make dedicated products to address it, in fact (see review link below for those three). It is present to some extent in essentially all broadcasts and DVD?s. If you have a recently acquired DLP, LCD or plasma display it may have added enough additional video delay to make it noticeable but lip-sync error comes from MANY sources starting at image capture and continuing through post production and broadcast or DVD encoding and it is cumulative. There is usually enough lip-sync error in broadcasts and DVD's to cause a negative impact on viewer perception (Research done at Stanford showed this.) Many people don't consciously notice it until it gets very large because it's such an unnatural phenomenon ( audio can't come before the action causing the sound in the real world) we apparently subconsciously avoid looking at the faces and seeing the lips move "after" the sound from them is heard. A study at Stanford proved this causes negative viewer perception even for those who don't notice it so this is something we all need to notice as you already have. For those reading this who haven't noticed it, take a close look at the LIPS - force yourself to overcome your natural avoidance mechanism that keeps you from looking at the lips - and you will see lip-sync error you never noticed before. I think you will be amazed that you could possibly not have noticed it before. You will be seeing what JC is seeing. I even see it now on CRT TV's and am amazed I never noticed it so it's very obvious some avoidance mechanism is at work. And back to JC?s solution: I'd recommend one of these digital audio delay units. That way you can correct for ALL cumulative lip-sync error no matter what its source might be. Any one of these units reviewed will correct it ALL. With any one of these units you can adjust for perfect lip-sync at the start of each DVD or broadcast and not disturb the image you are watching during that fine adjustment. I have had a Felston DD340 since 2004 (three generations earlier than the DD740 covered in the review) but it still has the most important feature of all these units from these three different manufacturers which is their "plus and minus" buttons on their remotes that allow you to tweak the delay while watching your material without upsetting the video your are watching. My av receiver has a built in delay of 80 ms which isn't even enough audio delay to offset the video delay my plasma display adds but even if it were it isn't practical to adjust it for the changes in lip-sync error from program to program and DVD to DVD since it overlays the screen with menus when making the delay adjustment. With my DD340 (and any of the units reviewed) all you have to do is press the plus or minus button until you get perfect sync. Here is the review I mentioned: [URL="http://www.audaud.com/article.php?ArticleID=3011"]
    Aug 30, 2007 | Audio Players & Recorders
    LG 47LX9500 47 3D LED TV with 480 Hz ($349999 before $35000 savings) 47 in 3D HDTVReady Logo
    389 people viewed this question
    Computer Repairing
    Computer Repairing
