Question about GPS
Unit Model N197 is not functioning - 2.5-3 years old. Appears to be a battery issue
  • anneben Mar 14, 2011
    Unit is a Navman
    Input 5V=1A
    N17865?
    S/N:BFF8AM01165
    Is there anywhere I can take it, I live near Parramatta NSW, Australia
  • 438 Answers
Anne,
If it is a battery problem then it should cone on and work when you connect it to the charger. Does it?
If not then does it show any signs of life when you power it on?
If there are any signs of life then it s the firmwarethat has gone corrupt and needs reinstalation. Please get it done.
Posted on Mar 14, 2011
  • 643 Answers
What brand gps is it
Posted on Mar 13, 2011
Www navman support
The unit originated in Australia where all Maps originate. They are not doing well at addressing updated Maps and providing customer support.
Feb 03, 2014 | Computers & Internet
My sat nav will not charge
Hello -
Possible solutions:
1. Clean the contact on your car charger - it may be dirty and not properly connecting.
2. Carefully, using compressed air if possible, clean the charging port on your navigation unit - it may have debris obstructing the charging connection. *Please do not blow into the port or use any liquid to clean it*
3. Attempt to charge the unit in another vehicle - your vehicle may be source of the issue.
4. Bring the unit inside and connect to wall outlet our home computer - the power cord for the vehicle may be malfunctioning.
Please note: modern battery technology does have a shelf life. Eventually the internal battery of the until will stop holding a charge and only function when connected to a proper power source. If your satellite unit is older, this may be the issue. If it is relatively new (less than two years old) and will not hold a charge, the unit may be malfunctioning and should be serviced by a professional or replaced.
Aug 13, 2012 | Cameras
Navman 40i appears to charge up but will not
if the unit is more than 2 years old the chances are the battery is defective/worn out, you say battery appears to charge up, so think you are unsure of the battery condition.
Sep 11, 2009 | GPS
LG Dehumidifier 3 years old stopped circulating resulting
Approached unit with air of trained appliance repair professional. Found Chinese-made product of vastly inferior quality, began series of tests, moving on to systematic disassembly finally sledgehammering the unit thence noting it failed to improve performance. resolved to not buy junk made in China or elsewhere. I've been "fix-ya'd" all right! Over and out.
Jun 13, 2009 | LG Dehumidifiers
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
No battery communications
You will get that message when the communications cable is not hooked up. It looks like a phone line and daisy chains from one battery to another and ends at the Matrix Control unit. If you have those installed and it still says no communication the system need service.
If you have a volt meter you can check the voltage from each battery at the plug. It should be 48 volts or more, usually on a fresh battery pack it will read 54.0+ volts.
Hope this helps,
Dean
Dec 09, 2008 | APC Matrix-UPS 5000 UPS System
Replace internal battery on garmin gps3
Hi - I have a Garmin GPS 2 plus unit which is around 10 years old. I haven't used it for about 2 years. Initally it powered up and eventually found satellites. I switched it on the following day and it will not power up. I have changed batteries but nothing works - tried a master reset but agin nothing - it appears to be dead ?
Ali
Aug 29, 2008 | Garmin GPS
Suddenly turning off
Your battery is dead. You'll need to return it to Garmin for repairs. Mine did the exact same thing. Functioned fine in the cradle - showed full battery - but shut off immediately upon removal. They know about the problem and shipped me a new unit for free.
Nov 28, 2007 | Garmin Edge 305HR GPS Receiver
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
GPS Logo
50 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
