Question about Hotpoint Washing Machines
My washer sounds like it is leaking but no water on floor but you can hear water dripping inside even when the water is off
  • 351 Answers
Most likely the water valve is stuck open...Post the model number and or call 877-293-1739 and i can help you out with ordering etc...
Posted on Mar 13, 2011
Water dripping onto passenger side floor from the inside passenger assist handle.
Does your car have a sun (or moon) roof? A leak in a sunroof will sometimes follow the roof over to the door post and down to the floor were the water will accumulate. This can be hard to find sometimes but having one person spraying water on the roof while a second one checks the inside of the vehicle you may be able to pinpoint the leak.
Hope this helps.
Bob
Jan 05, 2015 | 2003 Chrysler Town & Country
Why does the fisher and paykel washer gw11 drip water after cyle is finished?
If it drips inside than check and replace fill valve.
If it drips onto the floor check for a leak
Jun 05, 2014 | Fisher and Paykel Washing Machines
My washer sometimes ends up with a couple inches of water in the tub a day after last used. Also, at times water leaks on the floor. Neither of these things happen consistently.
It is likely that the fill valve located inside the rear panel is leaking, especially if you leave the supply lines turned on all the time. One annoying fix is to turn off the water supply after each laundry session but than you have to remember to turn the water on again next time
Dec 28, 2012 | Maytag PAV3240A Top Load Washer
Frigidaire gallery front load washer dripping sound
With any front load machine manufacturers suggest to leave the door open after cycles to help evaporate the water - this is even done in top loading machines nowadays. Also clean the unit with bleach water and rinse in high temp water cycles.
Aug 12, 2012 | Frigidaire GLTF1670A Front Load Washer
Slow drip of water inside the drum. Don't see no moisture but I can hear it dripping. No Moisture on the floor. Any ideas where it could be dripping from?
Turn the water faucets off and listen for the drip to stop.
If the dripping noise stops,replace the water inlet valve on the washer were the hoses connect.
Enter your model number in the site referenced here for parts.
www.appliancepartspros.com
Jan 24, 2010 | Maytag Washing Machines
Washer leaks out of the bottom. checked drain hose it is not plugged, checked hot and cold water hoses they're ok.
REMOVE THE TOP OF WASHER AND CHECK THE WATER INLET VALVE. I HAVE DONE EVERYTHING AND FINALLY DISMANTLED THE WASHER UNTIL I FOUND THE HOT WATER INLET VALVE WAS LEAKING FROM THE TOP AND DRIPPING DOWN THE TUB AND ENDING UP ON MY FLOOR. IT WILL DRIP EVEN WHEN THE WASHER IS NOT ON DUE TO THE PRESSURE BUILT UP ON THE VALVE.
Oct 25, 2009 | LG WM2688HWM TROMM SteamWasher
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
In the spin cycle water leaks onto the floor,
If the hoses at the back are not leaking, you need to check the drain hose lines, aksi check that the machine is not dripping from the inlet valve hose, or because of a leak from the door gasket.
Dec 09, 2008 | Maytag PAV3240A Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
