Question about Pentax Cameras
Asahi Pentex SP Spotmatic, need bottomplate with battery door treded.
  • 739 Answers
Hi, You are goi8ng to have to find repair shop with pentax parts in order to get this fixed. You can sometime find the parts on eBay - but you have to be lucky.
Posted on Mar 13, 2011
I have a Asahi Pentax SP Spotmatic Camera. im unable to crank the rapid winder lever. how can i resolve this.
If there is a film in the camera, then the interlock will prevent the film being wound on. Can you operate the shutter, or is that locked too ? If you are willing to sacrifice the film in the camera, open the back and remove it, then try again with an empty camera.
Sep 10, 2017 | Pentax Cameras
Asahi Pentax Spotmatic SP jammed shutter
Have the film come to the end of the roll and the camera will not fire, if so rewind the film. Sorry, a shutter is not a self service item. This should be sent in for a CLA.
Nov 04, 2013 | Pentax Asahi Spotmatic Sp 35mm Film Slr...
Need updated software for pentex Optoi W20 , soft ware S-SW58
The page containing all Pentex software downloads is at:
http://www.ricoh-imaging.co.jp/english/support/download_digital.html
Nov 03, 2013 | Pentax Optio W20 Digital Camera
Asahi Pentax Spotmatic SP The film rewind button is fully depressed and won't pop out, and the shutter button isn't working.
if the camera is jammed for any reason, then the rewind button will not pop out. on this model it was common that the mirror cock lever at the bottom jumped. in which case the camera will jam up.
remove three screws holding the bottom cover, remove cover. in the middle of the camera is a lever that needs to be latched by pushing it forward. the camera should release and revert to normal usage.
if this is not the case then there may be something jammed in the winding or shutter gears. in which case you would have to remove the top cover and/or front covers.
Aug 10, 2013 | Canon EOS-AE-1 35mm SLR Camera
Looking for a manual for asahi pentax camera 5799678 sp 1000
You may download a copy of the manual from here.
Feb 09, 2012 | Photography
I have an old Pentax ASAHI 35mm SP camera. It reads SPOTMATIC on the front. I can't see through the view finder. Any suggestions?
Remove the lens and look into the throat of the camera. The mirror should be resting at a 45 degree angle, but if it's fully or partially stuck upwards then the mirror has locked up.
There were a number of Spotmatic models made between 1964 and 1976, all were fully manual and mechanically operated so the battery was used only to power the light meter. This is important, as on later models the battery also powered the shutter and a flat battery would cause mirror lock up. On your model (either an SP500 or an SP1000), the lock up is either due to an internal breakage or simply due to dried out lubricants which may have been in there for around 40 years now. Fixing your camera requires professional attention; if you're lucky then the camera just needs a CLA service (Clean Lubricate Adjust), new light seals and possibly a battery recalibration (original mercury batteries are no longer available, modern "equivalents" have a different voltage). If this is done your camera can give many more years of service, but the costs will far outweigh the value of the camera. Millions of Spotmatics were made, and the only ones of value to collectors must be immaculate and fully complete and functional. If your camera needs spare parts then they simply aren't available except by cannibalising parts from others. Given that there are plenty of more recent, fully functional 35mm SLR camera outfits available for free on FreeCycle and Freegle you really need to appraise whether to sell your near-worthless camera for spares or to make an investment in repairing it. One benefit of your model is that it accepts the older M42 screw mount lenses and there are millions of them going for between zilch and peanuts.
Aug 16, 2010 | Pentax K1000 35mm SLR Camera
Unable to open DVD door
isnt there a hole in the bottomplate?
Apr 19, 2010 | LG RH177 DVD Recorder/HDD Recorder
I have a pentex k1000 camera with a tamron ae 28-80 and ae70-210mm lens. They have pentex mounts on them. Are these lenses adaptable to todays autofocus cameras like the canon eos or pentex k100
If it is a pentax lens then yes but only for pentax cameras...it wont fit a canon at least not to my knolege. pentax makes all there cameas with the same lens mount.
Jun 07, 2009 | Tamron AF 28-80mm Lens
I have a asahi pentax spotmatic sp II and dont have a manula!! i need help with opening it and using it! thanks
Hi - You can download the manual by clicking the link underlined in blue below:
spotmatic sp II
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 08, 2008 | Pentax Cameras
How do I know what size lenses to look for?
Hi rlopez117,
Congratulations on the aquisition of such a great vintage camera!
Pentax cameras use a mount known as M42. This means it is a 42 millimeter diamater. You may also find this referred to as the Pentax mount, as Pentax (Asahi Optical) made this popular in the United States. With any camera, any lens you purchase should match the mount of the camera in order to be used together.
Thank you,
Jason,
Go Ahead. Use Us.
Jun 25, 2008 | Vivitar Telephoto 100mm f/3.5 Macro Manual...
Cameras Logo
69 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
