Question about AcerPower S285 (APS285UC3521) PC Desktop
Unable to do install of XP. during install process pc reports unable to copy various .dll's and other files from install disk. install disk is in perfect condition.
  • youcanrea522 Aug 13, 2011
    It turns out that the problem was that one of the RAM modules wasn't agreeing with the other RAM module. Someone before me added RAM and although it was the correct kind it was by a different manufacturer. Both RAM modules are good when they are in the PC separately but when they are in at the same time, forget it. I did a memory check with both modules in at the same time, and it came up with memory issues, big time! That might also explain why the hard drive would heat up and make odd noises. I did more research and found that the voltages are different for each module.
    President:
  • 1,623 Answers
I would check the quality of the hard drive another thing to try is to copy the files from the install cd to the hard drive ,make a folder called win xp then copy them into there and try to install from the hard drive files. you will need a windows boot disk, with smartdrv on it too, to do this as you will need to boot to dos to run the install. once in dos from bootdisc type smartdrv and press enter , if you dont run smartdrv first it will take a long time to copy the files now type c:\ and press enter then type cd c:\winxp\i386 and press enter then type winnt and press enter again and setup will start. If install failsusing this method then i would try pulling one of the ram cards out of the pc as that is another reason , that i have found, which corrupts files when they are being copied
If you found this info useful please vote for me
Posted on Mar 13, 2011
  • 55 Answers
The message refers to the CD/DVD drive being unable to read from the CD itself. That could mean that either the disk is in bad condition and cannot be read (i.e. scratches, old disk, etc) OR that the drive has difficulty reading from the disk.
In the later case, it's the drive's fault and not the disk's (since you mention it's in perfect condition).
You could try cleaning up the drive but it's usually not worth it and since they're quite cheap, I would recommend getting a new DVD drive instead.
Hope that helps!
Testimonial: "Thank you for the assistance. "
Emachines T4010 won't start up, says image checksum, and that an image is corrupted
Receiving a bad image checksum error message when upgrading a computer to Windows XP means that a Windows system file such as user32.dll is damaged. This error occurs when any damaged system file is encountered that isn't overwritten during Setup. The repair process for this error involves voiding the damaged dynamic link library file from the DOS command line prompt and replacing it with a new copy from the Windows XP disk.
Insert a clean Microsoft Windows Millennium Edition (ME) or Microsoft Windows 98 Edition startup disk into the computer, and hold the reset button on the front of the computer until the system commences rebooting. Navigate the Windows startup menu with the keyboard's directional keys and select 'Start Computer with CD-ROM Support'. Hit "Enter" to continue. Write down your CD-ROM's drive letter on a piece of paper. At the command prompt, type "Drive:" without quotes (Drive should be replaced with the drive letter on which Windows is installed), and press "Enter." Type "cd windows\system32" without quotes, and press "Enter." Type "ren user32.dll user32.old" without quotes and again press "Enter." This renames your damaged user32.dll file so it is not recognized by the system, but still physically exists as a backup if needed in the future. Eject the Windows ME or 98 disk, and insert the Windows XP disk. At the command prompt, type "extract CDROMDrive:\i386\user32.dl_ Drive:\windows\system32\user32.dll" without quotes, replacing CDROMDrive with the CD-ROM's drive letter that you made a note of earlier, and replacing Drive with the system's drive letter on which Windows is installed. Hit "Enter" to execute the command. This process extracts a new copy of the user32.dll file to your hard disk, from the Windows XP CD. The new file will be found in the Windows/System32 directory. Restart the system by holding the reset button on the front of the tower until reboot commences.
Jan 03, 2013 | Computers & Internet
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
My computer keep showing dciman32.dll
That is some corrupt files in action. Reinstall your Operating System (Windows) or install a new one (Linux). Make sure to back up any files that you have before reinstalling, as files will not be preserved during the process.
May 04, 2011 | Computers & Internet
During installation a fresh copy of Windows XP, some of files can not copy to hard disk (driver.cab, spnike.dll, sprio600.dll, sprio800.dll, srgb.icm, streamci.dll and other files). How can I solve this...
Your disk is scratched and unreadable, that is why it can't copy those files.
A genuine XP disk qualifies for Microsoft Support. Contact them and ask for a back up, or replacement disk.
Your timeous rating of this solution is much appreciated.
Its the thums up on the top right of this solution.
Thanks
Nov 01, 2010 | ASUS A9RP Notebook
I just aquired a Dell PC that is newer than my HP PC. I have no idea on how to move all my files and programs over with out loosing anything. Can you send me some instructions through email? Thanks, ...
You cannot just move your programs over, you need to install your programs using the various program installation CDs, because the installation process copies DLL files as well as putting data onto the registery file.
You can copy your data files from your HP PC to a USB memory stick and then plug this USB memory stick into the Dell's USB port and copy the data files to the various folders on the Dell PC.
Sep 03, 2010 | Computers & Internet
Hello I have a Problem for Dell PowerEdge 400sc and cant get windows xp installed, I am able to reformat the HD but cant get xp to load and at one point during the installation it says it cant install...
try another windows xp disk or burn another copy of the disk you have. it's also possible that there's a problem with the optical drive that you're using.
Mar 15, 2010 | Dell PowerEdge 400SC Server
Had to reinstall XP operation system, now I am getting 2 Intel Audio Studio Controller error messages. Error 53 file not found IASMXDLL.DLL and Run Time error 53 File Not Found IASBB.DLL.
If you find a dll called iasdll.dll on your pc, you may have a spyware program known as 'invisible activity spy'. This process may have been installed via an installation package (potentially when another application was installed). The 'invisible activity spy' process has been known to monitor activity on pc's by capturing your key-strokes. Either you downloaded a hacked board driver or you have a bad copy of XP.
Mar 11, 2010 | Computers & Internet
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
When starting up Windows XP - the process stops and I get the message C0000135 application failed because user32.dll wasnot found. I have tried to start in safe mode but the same problem re-appears. ie:...
I've just seen this on another users pc, here is how i solved it:
Start from your xp disk (recovery disk that you got with your machine or retail copy of xp), when prompted go into recovery mode (press r at the menu)
when in the recovery mode go to c:\windows\$NtServicePackUninstall$ and type
copy user32.dll c:\windows\system32\
then type 'exit' without quotes to reboot
your system will now boot up fine
(note there may be a copy of the user32.dll file in c:\windows\system32\dllcache\ as well)
Dec 10, 2008 | Computers & Internet
AcerPower  S285 (APS285UC3521) PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
