Question about Pioneer MEH-P5000 MiniDisc Player
Input/cut out Hi i have two questions: 1, I have pluggled my ipod into the cd changer connectors but cannot switch to the input on the head unit-does the unit need a line voltage to tell it the cd changer is there? if so how can I fool it into thinking this? 2. The unit seems to cut out during playback of minidiscs and reads error 11 or error 12. how can I solve this? many thanks. windsor
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
With the first question, if you are using an ip-bus to RCA adapter to connect your iPod to the CD changer port on the back of the radio, it won't be recognized until you turn on the AUX function on the radio. In the main function menu (usually gotten to when the radio is powered off), there is an option to turn on AUX1 or AUX2. Do this (consult owner's manual) and you should get your audio to play through.
With the 2nd question, the errors may have something to do with the file format on the discs. Not sure though.
Posted on Aug 03, 2008
Wurlitzer 1050 100cd loads but wont play any sound, been told cd player gone, what is best and cheapest solution? maybe convert to ipod? if so how can I do this?
you mean you wanna input an ipod?, simply connect your headphone output to your ipod towards this mega changer. that is if there's headphone input of this jukebox, if not..get a cable with headphone input and rca left and right at the end to be inputed towards the jukebox unit..
Oct 16, 2013 | Wurlitzer Jukebox 1015 One More Time...
Hey guys, I've just installed a CD changer in my car - having some difficulties getting it to work. After some Googling I came across this forum so I figured I'd see if any of you guys know where I'm...
there should be a small connector on the changer itself for the power ground and remote wire for power to the changer unit. the cord coming from the unit to the changer doesn't supply this power and this is why it wont eject and also your head unit wont recognize it until it gets powered up and able to communicate with the head unit and then it will show up as a selectable source when switching between sources of music. check the back of the changer for a small connector containing 3 or 4 pins and you should have a connector with the corresponding wires coming from it to plug into this spot after connecting the wires properly. if you bought it on ebay it is possible you didn't get this piece which is critical when connecting this changer.
Apr 03, 2011 | JVC CH-X1500 12-Disc CD Changer
Hello my car is equipped with a Sony CDX-L410X head unit and i want to be able to connect my ipod directly to the head unit. the head unit does not have an aux or usb port on the front does it have an...
Hello! Maybe I can help with your question. This model headunit does not support ipod control. It does not have rear or front inputs via 1/8mm jack that you could use the headphone output. You only have a couple of options here. First would be to purchase a wireless fm modulator that would transmit the ipod output through your cars antenna. (i.e. set the radio to 88.1, 88.3, etc) These can be purchased at Radio Shack, Wal-Mart, etc. The only other option would be to replace the headunit with a compatable unit. We sell a Kenwood for $139 that has a front USB port as well as the aux input. The USB on this unit reads droid phones and ipod. That model number is KDC-248U. Hope this helped! Good luck with your venture!
20 year car audio/video installer
Bay manager
Mar 14, 2011 | Sony CDX-L410X CD Player
I have no CD changer and want to use this audio input jack as a auxillary input. How must I wire the cd changer connector to get access to this audio input
Any audio source with 3.5mm out jack can be connected to this input, eg. cd player, ipods, cellphones etc.
Aug 15, 2009 | Clarion DRX5575
CD changer output not working
There is an obscure setting for 'AUX' on/off that is hard to find unless you know what you're doing or looked in the manual. Typical Pioneer for ya.
Apr 19, 2009 | Pioneer DEH-P3600 CD Player
JVC Daisy Chain
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
Feb 22, 2008 | JVC KD-G421 CD Player
Cd input?
I'm afraid it would be a complicated task to tap into the line input on the cd changer connector because the line input only becomes active when a changer is connected, so you would have to connect a device that would talk to the head unit to tell it that a changer was there
Nov 21, 2007 | Denon DCR-670RD
Help
Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | JVC KD-G720 CD Player
Linking an i pod to a Sony CDX-MP40 using the bus input terminal
Some Sony head units let you use the Bus audio inputs as an auxiliary source input, but yours is not among them. To play your iPod through the head unit, you'll either need an iPod interface module: http://www.xplodsony.com/xplod/accessories/XA-110IP or an auxiliary input module: http://www.xplodsony.com/xplod/accessories/XA-300 The iPod interface will allow you to control and display the iPod directly through the head unit, while an auxiliary input adapter will allow the iPod to play through the head unit using the iPod's controls and display.
Jun 01, 2007 | Sony CDX-MP40 CD Player
MD/CD Changer Control Options
press source button repeatedly to select "CD" or "MD" be aware that in order to connecting Ipod to a car stereo you will need to use an extension cable with 3.5 mm stereo connectors on each end to connect iPod to your car stereo system's aux input, or use a cassette adapter if your car stereo doesn't have a sound input jack. Either of these items can be purchased at stores that sell car stereo accessories. good luck!
Nov 12, 2005 | Sony CDX-CA400 CD Player
Pioneer MEH-P5000 MiniDisc Player Logo
104 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
