Question about Logitech Harmony One LCD Touchscreen Remote Control
Low sound on harmony one - Logitech Harmony One LCD Touchscreen Remote Control
  • 40 Answers
Is the remote set to adjust the volume on the TV? If it is going up all the way to 100% or Full on the TV then suggest checking the source. On some cable and satellite boxes they have a built-in volume control also. If that is set low, that would affect the amount of volume coming out of that device.
Posted on Mar 13, 2011
Harmony will not pick up sound from Bose, for TV
Advanced remote controls such as your Harmony can be programmed with a macro to automatically execute a series of commands. What you need to do is work backwards through the automatic sequences to separate functions you wish to control manually (such as volume).
Jul 01, 2014 | Logitech Harmony 525 Advanced Universal...
Sony Bravia HDX-285 My center speaker does not put out any sound. I tried changing the input and it work fine in the other inputs. I tried a different speaker in the center speaker input jack and no sound....
Your surround capability is 5.1. Although there is a front panel function button, there appears to be no other buttons to program your unit without the remote. Find your remote or replace it. Ebay is showing replacements at what I consider a low cost. The Sony model is RM-ADU007. Failing that and considering the many remote functions required for you unit, would be a Logitech Harmony replacement. The Harmony remote also comes with a USB patch cord because the user must go online with Logitech to program the remote for your unit. It would be best to the Harmony website prior to buying to make sure it covers your model.
Nov 30, 2017 | Sony Audio Players & Recorders
Open battery compartment on Logitech harmony 700
When you take out the battery, the remote will reset itself. You have to setup once more with the codes for your device.
Jul 13, 2012 | Logitech Harmony 700 LCD Remote Control
Setting up my Harmony 880 to work with My Sharp Aqous TV and LG 3400 DVD player - I gt no picture or sound
Begin the Setup Process
Step 1: Create your Harmony Login
If the Harmony remote web site is not automatically launched, go to the Harmony remote web site and
create an account.
Step 2: Complete the Online Setup Process
Once you have created your Harmony login, the online setup process begins. You will guided through a
series of question-and-answer steps to complete each of the five main steps of the online setup process:
1. Identification: Requires you to create a login on our member web site.
2. Check Connection: Ensures your computer and your Harmony remote are communicating
properly.
3. Set up Devices: Helps you set up a description of your personal home theater system.
4. Set up Activities: Helps you set up a description of the connections for devices that allow you to
perform Activities (e.g. Watch Television Activity).
5. Update Remote: Updates your remote with your personal configuration.
Jul 09, 2012 | Logitech Harmony 880 LCD Remote Control
Low battery icon on, won't recharge
Hi. If you do some research, you will find that this is a common issue with the Harmony One remote. I suggest using an elastic band to hold the remote firm onto the charger. That works for me.
Aug 03, 2011 | Logitech Harmony One Advanced Universal...
LCD Display is broken on my harmony SST-659
I wish there was a low cost solution to your broken display. However, the cost to repair will run more than a new remote.
I would recomend the Harmony 510 for a replacement.
Link below.
http://www.amazon.com/Logitech-Harmony-Advanced-Universal-Control/dp/B001F51G1Q
With many electroics these days, it is cheaper to replace than repair.
Good Luck
I hope this helps.
Mar 21, 2010 | Logitech Harmony 659 LCD Remote Control
Harmony 785 charging cradle does not charge the remote. The cradle lights up as normal. There used to be a sound when the remote was put on the cradle, but it stopped a few weeks ago. The remote shows a...
Try pressing down on the remote, and wiggling it around. It's just that the pins are not making contact I suspect.
If pressing down helps, you can fasten it on with a elasitc band or something so that it keeps charging. Also, if it is still under warranty, I woul advise contacting Logitech's wonderful support team to get replaced.
Hope that helps!
Feb 14, 2010 | Logitech Harmony 785 LCD Remote Control
Harmony 520 no sound control for tv
I can help you program your Logitech Harmony 520 remote for your TV.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Sep 28, 2009 | Logitech Harmony 520 LCD Remote Control
Display shows "Harmony safe mode" and will not respond/turn off
remove one battery. press and hold the #2 while replacing the battery. hold the #2 until you see "upgrade success". press activities and you're back in business.
Mar 07, 2009 | Logitech Harmony 550 Remote Control
Logitech Harmony One LCD Touchscreen Remote Control Logo
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
