Question about Microsoft Computers & Internet
I try to download microsoft office but get write a block to a pipe failed on screen.
3 Suggested Answers
greed03
  • 386 Answers
SOURCE: Windows vista 32 bit,SP2 For some reason I cannot
It's happened to me before...LOL.
When updating Open Office, I actually had to directly connect my laptop to the router. For some reason, when i was wireless, it would drop signal, or signal would be too low, especially if there was more than one computer active on the network.
Hope this helps!
Posted on Dec 19, 2010
Donateli
  • 74 Answers
SOURCE: Hi!! How are u? My
OK, sounds like the problem is that the computer cannot get a valid IP address. In fact it sounds like you might have a IP address conflict on your network. Each IP address on a network segment must be unique.
Check if you are using DHCP.
  • Go to
  • Control Panel
  • Network connections
  • Locate the network connection you are using e.g. 'Local area connection' or perhaps 'Wireless connection'
  • Right click on the relevant network connection
  • Select 'Properties'
  • Select Internet Protocol (TCP/IP)
  • Select Properties
Is your machine set to "Obtain an IP address automatically" (DHCP) or "Use the following IP address".
If its "Use the following IP address" then make sure no other machines are also using this IP address. You can try setting to 'automatic' but if you do, make sure that you note all details first, so you can revert back to the settings you currently have if you need to.
if its "Obtain an IP address automatically" then make sure no other machines have been manually set.
With regards to the microsoft update, then your best bet is to only select a small number of updates at a time, until you determine which update(s) is causing the failure. Once you know which update is the problem then you can troubleshoot the specific update.
Hope this helps
Please take the time to rate this answer. Many Thanks Don.
Posted on Sep 05, 2011
I bought $89 office 365 from Dick Smith. How can I install with that? Ellie
Common causes for error code
  1. Antivirus software or firewall might be blocking the Office installation and causing error code
  2. Internet connection or proxy settings are preventing from installing Office results in error code
  3. Pre-existing version of an Office suite is blocking the installation resulting in error code
  4. Incomplete\partial\failed repair\installation\change\removal of a previous Office suite can prevent from installing a newer version can cause the error code
Follow the below steps to troubleshoot the error code
1 - Repair your Office app to fix the error code
error code will be fixed when Office repair tool replaces all the corrupted system files. Follow the steps below to run repair tool to fix the error code
  1. Open Control Panel using Start.
  1. Click on Programs and select Programs and Features.
  2. Click on the Office product that you want to repair.
  3. Click Change.
  4. Select Quick Repair and click on Repair. If Quick Repair didn't fix the error code, select Online Repair and click on Repair.
Note: If Office Repair did not fix the error code, remove and reinstall the Office Suite to fix the error code.
https://answers.microsoft.com/en-us/msoffice
http://microsoftsupport.cc/
Feb 02, 2016 | Microsoft Office 365 Personal 1yr...
Tip
How to activate office 2007
Office Genuine Advantage (OGA) is another anti-piracy initiative by Microsoft on its popular business productivity product – Microsoft Office XP, Office 2003 and Office 2007. Similar to Windows Genuine Advantage (WGA), OGA requires users of the Microsoft Office software to validate their installed copy of Microsoft Office in order to download files from Microsoft Download Center, access updates or hotfixes from Office Update, and receive special offers for genuine users.
OGA is not to be confused with Office Product Activation that is mandatory required to during the installation process in order to use the Office software whereby users enter a serial product key that is validated online over the Internet or by phone by Microsoft to confirm that the product key has not been used on more personal computers than are permitted by the Microsoft Software License Terms. To crack Office XP/2003/2007 activation, you need a key generator that provides volume license key (Guide: How to change Office 2007 product key).
If you’re using a keygen-generated product key or publicly available leaked Office 2007/2003/XP serial number, especially the volume license key (VLK) that requires no activation when used, most of the keys no longer able to pass the OGA genuine validation test anymore with the following error message (Office 2007 as instance):
office-fail-validation.jpg This computer has failed validation.
Microsoft Office Enterprise 2007: Validation Failed
The product key used to install Office is not valid. It has been identified by Microsoft as a false key used with counterfeit copies of Office.
[0x80180108]
It’s likely that users who failed validation check may continue to use Microsoft Office as per normal and use Microsoft Updates to update critical patches. However, if you want to download add-ins, updates, templates, samples and tutorials, Smart Tags, Language Interface Packs and Software Development Kits (SDK) that require Genuine Office validation, you won’t be able to do so.
To bypass or crack the Microsoft Office 2007 and Microsoft Office 2003 OGA genuine validation, follow these steps:
  1. Install and activate Microsoft Office 2007 or other version of Office. If you intend to use the key-gen, you must install Enterprise edition.
  2. Download the patched ogacheckcontrol.dll.
  3. If you never validate your copy of Office, go to Genuine Microsoft Software web page, and run the Office Validation Assistant by using Internet Explorer (not Firefox as it will use different version of ActiveX component). This is to install the components required for Office validation. If you fail the validation – Office not genuine – simply ignore the message.
  4. Copy the cracked ogacheckcontrol.dll to the following location: Windows XP and Windows Vista (32-bit): \Windows\System32\
    Windows XP and Windows Vista (64-bit): \Windows\SysWOW64\
  5. Attempt to download Office files that require validation again. All downloads should work now.
The OGA Check Control crack works on Office 2007 Enterprise Edition, Office 2007 Blue Edition, Office 2007 Professional Edition, Office 2007 Pro Plus, Office 2007 Standard Edition and all Office 2003 Editions.
If you’re using invalid or blacklisted product key, you may have to change the Office product key (Guide: How to change Office 2007 product key). This is especially so if you’re using Microsoft Office 2007 Blue Edition.
Disclaimer: This patcher is for genuine Office user who having problem to pass genuine validation only. To use Office 2007, you must purchase a licenseir?t=techgadgetrev-20&l=ur2&o=1. Alternatively, you can use for free OpenOffice.org, an equally good productivity suite.
on Aug 02, 2010 | Computers & Internet
Why isn't my purchase of Microsoft office home & Student 2010 not downloading?
Try a different browser. the characters are the command for your browser to download the file but it's not being interpreted properly. This may mean your browser is out of date or you have blocking software preventing it's proper operation.
Sep 13, 2014 | Microsoft Office Home and Student 2010
I TRIED ABOUT 10 TIMES TO DOWNLOAD MICROSOFT OUTLOOK ORDER # 11160568 AND WHEN ABOUT TO BE COMPLETE THE DOWNLOAD FAILS DUE TO AN ERROR. PLEASE HELP ME
Hi
You do not say where you are downloading from or if you have paid for the download.
Genuine, licenced, MS Office Outlook is not available as a free download.
Either the source of your download is not a genuine, reputable one or there may be a corruption in the Office Outlook files installed on your computer causing an incomplete or corrupted download.
Start > Control Panel > (Add or Remove Programs) Programs > Uninstall a program > highlight MS Outlook > Remove all components of MS Outlook > Close > Restart computer > Download again (from a reputable source).
MS Outlook is no longer available as a download from Microsoft, see here:
http://office.microsoft.com/en-us/outlook-help/results.aspx?filter=5&qu=download&av=zol120
If you insist on using Outlook 2007, you will probably have to buy the software, or pay to download it from a reputable site, such as:
http://download.cnet.com/Microsoft-Office-Outlook-2007/3000-2367_4-15311.html
If you want to download from Microsoft, it will have to be MS Outlook 2010 from here:
http://emea.microsoftstore.com/UK/en-GB/Microsoft/Outlook-2010
I hope this helps.
Aug 27, 2011 | Microsoft Office Outlook 2007: Windows
I want to download Microsoft office 2007 for free :)
Have an idea on how to download Microsoft Office 2007 for free but this isonly a 60 day trial. Follow this steps Log on to Microsoft Office Online Click "Word2007" under "Office Products" on the bottom left to view theWord 2007 homepage. If you don't see this link, click the "Products"tab at the top of the screen, and click "Word" on the left pane Click "Free60-day Trial. This will allow you to download a free trial of Microsoft OfficeProfessional 2007, which includes Word, along with several other programs, suchas Publisher, Outlook and PowerPoint. Click "Download Now." Sign in with a WindowsLive ID. If you don't have one, click "Create New Account." Continuethe on-screen prompts to register with Office Trials and download the freetrial to your computer
Nov 13, 2010 | Microsoft Office Professional 2007 Full...
How to download free ms word 2003 on my pc?
Download using torrents and you will get the MA office full with product key but DO NOT LICENSE THAT PRODUCT KEY WITH MICROSOFT. It will work on your system and it will never expire but if you tried to update it or register it with Microsoft it will stop working and Microsoft will block it.
Nov 10, 2010 | Microsoft Office Professional 2007 Full...
I have Outlook and I can't get my emails. All the
Go to microsoft support and see if it find any problems when it searches for upgrades. Failing this, do a manual download of your emails, sometimes this is the cause of the block, ie an email gets blocked for some reason and wont allow others to pass. The manual download releases it.
Dec 30, 2009 | Microsoft Office Outlook 2007: Windows
Microsoft office basic edition 2003
Try using the Office 2003 removal tool. Just download the Office 2003 Editions Resource Kit at this link. It's called ork.exe:
http://www.microsoft.com/office/orkarchive/2003ddl.htm
After it's installed followed these directions:
To locate the tool, click the Start button, point to Programs, point to Microsoft Office, point to Microsoft Office Tools, point to Microsoft Office Resource Kit, and then click Removal Wizard.
Then follow the on screen instructions that will walk you through the removal. After Office is completely removed, restart and try to reinstall.
Hope this helps!
Mar 08, 2009 | HP Compaq Presario sr1010z PC Desktop
Visual studio instalation problem
just take a look to this site:
http://www.codeproject.com/
you will get your answer there easily.enjoy it!
Feb 23, 2009 | Microsoft Visual Studio® 2005 Professional...
Product key for a downloaded & updated version of ms word 2007
download open office www.openoffice.org
this is a software which ll give u all microsoft office product .. it is absolutely free of cost
Good luck
May 23, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
265 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
