Question about Refrigerators
Jenn-Air JBR2086HES bottom freezer, is warm in refrigerator section but freezer is OK. Refrigerator doesn't seem to be getting cold-air circulation. Freezer shows minor frost build-up. Display shows "3" for both refr and freezer. Electronic board replaced about 6 months ago due to total cooling failure in both sections.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 19, 2011
  • 2 more comments
  • dhgulley Mar 19, 2011
    Yeah, apparently it was the, advanced defrost control board, but this is the second time this board needed to be replaced within 6 months. The first time, the repairman mentioned that I should install a surge protector, which I did, so what would have caused the board to out again if a surge wasn't the problem?
  • D. Floyd Kolb
    D. Floyd Kolb Mar 19, 2011
    The other problem is low voltage or a brown out condition.... not much you can do about that....problem is that they make the boards as cheap as possible and that means skimping on everything then if anything goes just a bit off the board burns up...really stinks!!
    Well,, now that I know what it is, I'll just , "do it myself" next time and save myself the $400 repair bill! Thanks!
  • D. Floyd Kolb
    Yes... just do a search for "appliance parts" and enter the model number and you can buy the parts... they are not hard to install...
    Here is a tip that will help you with the onlinebuying...
    How to Buy Appliance Parts Online
    heatman101
Refrigerator side freezing
you could have a bad damper,this is located in the fridge section,all it is is a door that opens and closes to let cold air into fridge,sounds like yours is stuck open.remove the bottom kick panel and look for the tech sheet,it will tell you how to put it into diagnostics,the board will open and close,if it doesn't you know it's bad.go here and look at part number 13
http://www.searspartsdirect.com/partsdirect/part-model/JENN-AIR-Parts/Refrigerator-Parts/Model-JBR2086HES/1266/0161000/M0610191/00008?blt=06&prst=&shdMod=
Jul 12, 2012 | Jenn-Air JBR2086HES Stainless Steel Bottom...
The temperature in both the fridge and freezer aren't working . There is power ,but we are not able to cool it down
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Not cooling top and bottom freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 05, 2010 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Freezer seems to be ok. But refrigerator is not cold??? any simple fixes would be greatly appreciated
Somewhere in your fridge should be a fan that circulates air from the freezer section toi the fridge section. Chances are it is not running.
Jun 21, 2010 | Jenn-Air JSD2789GES Side by Side...
Jenn Air bottom freezer refrigerator not cooling properly,
This may be your compressor. You'll probably need a hard start kit put ont he compressor if it's not still under warranty. I hope this helps you out!
Aug 13, 2009 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Side-by-side fridge is freezing food on bottom shelf
Look to the freezer section for a possible frosting on the back wall. If you have a defrost problem in the freezer and air circulation stops cold air from the freezer may settle through the return area of the duct between the refrigerator and freezer section because cold air is heavier the warm air. Normal circulation follows a clockwise pattern.
Also your setting of the refrigerator temperature may be set to cold. Once again cold air settles to the bottom.
Jun 02, 2008 | Whirlpool Refrigerators
Refrigerators Logo
588 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
