Question about Kitchen Ranges
Screen says Err F4E2 internal sensor How do I clear screen and operate micorwave?
I toggled off the main power supply to the oven for about 10-15 minutes and then on. Problem solved . . . hopefully, it remains solved..
Posted on Jan 21, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Kitchenaid oven KESA907. Ran the self-cleaning cycle...
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 28, 2010
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
How do i fix the error 000003-0000 on ir 3320?
Hi
Whilst looking through the web I found this procedure for clearing errors from ir series Canons. You might like to try it first.
  1. Additional Functions: Click the Additional Functions button once. Do not hold down.
If this doesn't work, I found a complete list of error codes here:
Error Codes Canon iR3320
There are 12 pages of them but yours appears to be on the first and related to the temperature of - or lack of - the fixing unit. From this site you can also buy a service manual which may also be helpful to you rather than the User Manual/Guide.
Cheers
Nov 14, 2014 | Canon Office Equipment & Supplies
Error 1204
PSL stands for "position sensor-left". Check the left sensor for dust or some obstruction on that sensor. The operators manual will show you where that sensor is.
Feb 13, 2014 | Glory GFR-V20
Canon ir2420 restart the machine if ploblem persists,call service representative E000003 0000
On the operator control panel, next to the nine key pad,is a button that says "additional functions" locate it and we will perform a 3 step function that will allow you to enter "service mode" which will let you clear the code. Press "additional function", release it and then immediately press the 2 and 8 buttons simultaneously, release them and then press additional functions again. As I said this is a 3 step process that should be done in a smooth but timely fashion. If done properly this will summon a new screen that will show you a few "blocks" and the top block will say COPIER. Press it and a new screen will appear which will have several blocks across the top of the screen. One will say FUNCTION and you need to press it. Again a new screen. Look at the menu in the body of the screen and you will see CLEAR. Press clear. New screen again and look for ERR. Press ERR. After you have touched ERR notice the "OK" button in the lower right corner of the screen. Touch "ok". Now unplug the copier and power off. wait a few seconds.Now plug that cable back in and power on. The copier will attempt to return to a ready condition by "warming up". This is where the copier may notice a problem with the temp. Then make a copy. This will force the copier to run a brief diagnostic(which you wont see). If the copy successfully exits the copier then you should be ok. But the fact that the code occurred at all Means that at a minimum the copier had previously seen a problem and so the code may return. Good luck and take care
Feb 06, 2013 | Office Equipment & Supplies
Pope digital set automatic tap timer screen shows "err"
These timers seem to be very robust and one has been operating for several years without any problems. After a period of rain I turned the tap off to prevent the timer turning the water on. The "err " message was there when I next went to turn the tap on. Judging by the intstructions there is an internal battery of some kind which flashes a "OP" message. I took out the main batteries and the "OP" signal started to flash, I then removed the four screws from the back of the timer but could see no obvious way of resetting it. I took a guess which luckily turned out to be correct and briefly bridged two contacts on top of the timer (see picture). The screen went blank and when I re-installed the batteries it had re-set itself to. All buttons are also working.
I imagine that there have been many of these thrown out with the garbage un-necessarily when the solution is quite a simple one. Pope would be doing a service to the planet by fitting these timers with a reset.
Feb 01, 2013 | Washing Machines
I am getting e020 error switch main off and on again and again
e020 error is of the main fuser unit u can solve it by press *28* then goto copier then function then clear and clear err dc-con err-hist jam-hist and pull both 1st and 2nd drawer now restart and when the screen is ok again restart then on main screen insert both drawers ur err will be removed -tushar sharma tushar@easy.com -9403343433
Mar 22, 2011 | Canon imageRUNNER 600 Printer
heatman101
Apr 27, 2010 | KitchenAid KESA907PSS Electric Kitchen...
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
001 error occur
error for faulty temp sensor we can try to clear 1st if it comes back you need to have the thermister changed..... inthis order press add func key / then 2 & 8 key at same time / then add function key again . ( you mayneed to do this acouple times) screen should change to serv mode then in this order touch copier / function / clear / err / ok turn off copier then turn on good lick
Jan 01, 2009 | Canon imageRUNNER 5000 Copier
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
