Question about Chamberlain Clicker Universal Garage Door Entry Keyless
The key pad no longer works, somehow seems to have become unprogrammed, along with the remote openers. I have reset the remotes but cannot figure out how to reprogram the keypad. All instructions I can find online say to enter the new code and press "enter" but there is no enter button on my model.
  • 17 Answers
SOURCE: I am not able to program the 3 button Remote
There should be a programming button on the door motor. Press that button and then press the button on the remote to program. Assuming they are compatible. If that doesn't work I will need the model number of the door opener and remote.
Posted on Jun 11, 2010
  • 10865 Answers
SOURCE: Re: Chamberlain Model 953CD. I would
Hello fwe... It is unlikely that your old remote and receiver will be compatable with your chamberlain. That said, it is certainly possible to do what you desire. Here is a compatability chart that may be of interest to you. http://www.aaadooropeners.com/remotecompatibility.htm
IF your gate is used by other residents you may not be able to make the modifications to your gate that are needed to use the chamberlain remote control. It may be worth a call to a couple of local garage door opener installers for their insights and also as a source of parts if in fact you are the sole user of the gate and can modify it to your chamberlain remote control. Joe
Thanks for choosing Fixya!
Posted on Dec 09, 2010
  • 1082 Answers
SOURCE: I have a 1990 Wayne Dalton opener with remote
The system is limited in the number of openers it can store. Usually 3 though I don't know about your model..
You need to clear all stored openers, and then re-add what you want to use. If there are 4 or more it will not work.. The last one entered will be replaced by the new one. (What you're getting now)
Usually to clear memory, hold down the program button for ten seconds or so.
Wait a few seconds, start installing your openers.
Good luck
Posted on Dec 27, 2010
dcramer531
  • 1654 Answers
SOURCE: I have a Chamberlain Model 8200 installed in 1999.
Anytime you can run your door down by holding the wall button down and it doesn't work on your remote it is always a motion sensor problem. If you look in your manual it will confirm this. Adjust your sensors so they are pointing at each other and both lights are on solid and check for loose wires to sensors or bared wires on sensors. All of the above can contribute to this same problem. This sounds like a sensor problem. Are both lights on the sensors on? If not the sensors need to be replaced. Easy . On the older craftsman both lights will be soild green if photo eyes are working properly. On the newer craftsman operators one will be green and one will be yellow if the photo eyes are working properly. If one light is on but one is not photo eyes might need to be lined up or there could be a broken wire. One other way to takle this issue is to increase the number of kg going down arrow which you can find at the back of your receiver. First try to increase it by one bar using a coin or screwdriver. If it's still not working, try to increase again by another bar. The only thing left is to make sure the tracks are not misaligned, if they get hit you could cause a binding condition. Sunlight can also interfere with the sensor operation, check and make sure they are working in direct sunlight.
Posted on Jan 14, 2011
  • 59 Answers
SOURCE: lost manual, installed new garage
Heres a link to the manual Chamberlain KLIK2U
Posted on Apr 03, 2011
Volume and channel up/down keys remote probs
The remote's broken.Find the replacement of the remote with same type, or
if you want to do it yourself, open the remote case, then try cleaning all the rubber pad and the button pad inside the remote using alcohol, this should works.
Mar 07, 2010 | Toshiba CN36V51 TV
Remote key no longer working
two main issues with remote keys.
1. the battery may need replacing see if the remote key has a light that comes on the key itself when a button is pressed if not that indicates the battery is flat or the key has got wet.
2. the kay can become decoded from the car. for security reasons the dealer should be able to reset this. this may happen if the car battery has been detached from the car or has run low.
again your dealership or our certified mechanic should be able to remedy this.
a final point is that the key has become damaged, if your spare key works as usual then you can rule our point 2 above.
Feb 01, 2010 | 2007 Infiniti M35 Sport Sedan
I have a rcr3273 universal remote. my tv is rca. i had the remote programmed before and somehow it became unprogrammed. i dont have the instructions anymore and i cant get it working
hold down tv button and power button together until the lcd light turns on. then press the play button every 5 seconds until your tv turns off. press reverse every 2 seconds until it turns back on. press stop to save the programming code.
Nov 09, 2009 | RCA Universal Remote Control
PHILLIPS UNIVERSAL REMOTE CL032 NEED CODE FOR PANASONIC TV
Panasonic 0 0 5 1 ,0 2 5 0 ,0 0 5 5
try those
Please rate opur help to keep the FREE service online ++++
Aug 31, 2009 | Philips PM3S Remote Control
Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Aug 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote control doesn't work
The only thing that comes to mind is somehow the remote became unprogrammed. This happens with some factory remotes, if you reset the code for the remote it may start working again.
There are other times (both of these Ive had experience with) when the remote will just stop working due to a defect.
Post back for any further help, thank you for stopping by Fixya!
Jun 21, 2009 | Samsung DVD-V5500 DVD Player/VCR
1996 Toyota Celica remote security system no longer works
Hi, Contact your dealer and get instructions for reprogramming your remotes. When a security system loses power for an extended amount of time the programming for the remotes are lost.
Mar 09, 2009 | 1996 Toyota Celica
Rca remote olevia tv
Here is a web sight I found that may be the perfect solution for your problem. I hope it helps. Good Luck.
RCA Universal Remote Control-Programming Codes
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | RCA RCR311B Remote Control
Chamberlain Clicker Universal Garage Door Entry Keyless Logo
37 people viewed this question
Top Chamberlain Building Materials Experts
Terry Smith
Level 1 Expert
Joseph Hoffmann
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
