Question about Marvel Refrigerators
My marvel kegerator model 61hk keeps freezing the beer at every temp setting
  • ctg9665 Feb 03, 2009
    my refrigerator keeps freezing as well, i turn it off for a few hours and then turn it back on and it goes to zero no matter what setting I have it on.
  • David Welch
    David Welch Jun 28, 2014
    My unit is having the same problem...we just replaced our thermostat...hoping it works! Did it work for you? HK61SS
  • 770 Answers
Replace the cold control (Temp Controller) it is not turning off the compressor
Posted on Aug 01, 2008
Hi I just got my EdgeStar Deluxe MINI Kegerator. I set the temp to 38 degrees for 24 hours + and all I get is foam. What am I doing wrong? I've switched back and forth from the manual tap and the
the difference between foam and beer is known as 'change of state', also applies to refrigeration equipment, and is caused when pressures drop too radically. While temperature is a factor, you need to consider your pressurization method and settings more. What are you using to re-pressurize your keg as you dispense brew? CO2? Nitrogen? mix? assuming you dispense from the bottom of the keg (feed tube reaching down near the bottom) lowering the pressure should help reduce the amount of foam when pouring. The thing is, even if you pour a glass full of foam, it will settle over time into beer, and you can add to it until eventually you have a smiling glass of amber joy sparkling at you. Go check some of the articles at
Aug 11, 2014 | EdgeStar ES TBC50S Deluxe Mini Kegerator...
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
My kegerator is sub freezing even on the lowest setting
I'd deffinatley say thermostat if it wont shut off or over freezes.
Nov 24, 2013 | Carrier BVA-BM23B Draft Beer Cooler...
The temp guage does not work and when the keg cooler is plugged in it gets down to 20 degrees and freezes the beer. Can this be fixed?
This solution probably costs more than you care to spend on the problem, but you can buy an external temp controller like this one:
You run the probe into the fridge and plug the fridge into the controller. Then the controller will only turn on the fridge if it gets warmer than the temperature you specify.
You might be able to find it cheaper on ebay, too. I'm using this on a kegerator and can keep my beer at a consistent temp.
May 10, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
The beer froze in the chiller what could be the problem
The thermostat is stuck in the closed position if you noticed that the unit runs and runs and runs without cycling off sometimes. If it cycles, move the thermostat setting up in number (warmer). Make sure, if the unit is in your garage or otherwise not inside where it is warm, that the temp of the outside air isn't below freezing - coolers don't do warming and will not protect the beer from frigid atmospheric temps. Good luck.
Apr 20, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
I have a Sanyo kegerator that will not cool enough. I have set the thermostat as cold as it will go and it will only go down to about 42 degrees. What can I look for?
Drop thae stat it's a screw on the left side that controls temp.Don't rush this you don't wnt to freeze your beer. 1,5 turns to the left will take you down to ice cold beer.
Nov 18, 2008 | Sanyo Refrigerators
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Does anyone know anything about kegerators?
first send it to me with a full keg so i can check it out what make and model is it and how are you pressuring have you checked the pressure gauge to see what happens when you open the tap
Dec 31, 2007 | Summit Commercial 500SS Draft Beer...
Refrigerators Logo
832 people viewed this question
Top Marvel Refrigerators Experts
ray gallant
Are you a Marvel Refrigerator Expert? Answer questions, earn points and help others
