While reading my novel the screen went white, i have tried holding the power button and the volume button but no message appears,i have tried charging it but i dont get a red or green light
    Problem Solver:
  • 10 Answers
When you restart, do you continue to have a white screen? If you do, it is probably the video inverter. Usually an inexpensive ebay item. Just take the bezel off your screen, the inverter is located at the bottom center. It has wires at each end. Unplug them. It may have 1 or 2 screws that need to be removed. Reverse this proccess with your new inverter.
If you are getting no lights at all it could be a bad power port or bad charger. Try to gently wiggle the plug around. If you get no lights, check the charger, you may need to replace it. If you get any lights then the solder on that port has probably broke loose. Very common. This involves a complete disection of your laptop, and the power port will have to be replaced. Only do this if you have good soldering skills. I would
Posted on Mar 14, 2011
How do i reset to factory mode if i forgot my pattern
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Pandigital Novel 7 to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Pandigital Novel 7 and including third-party applications.
9. The Pandigital Novel 7 will reboot to its original data.
10. This time you can restore your backed up data to your phone.
Mar 06, 2015 | PANDIGITAL Novel 7
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
How do i get to the BIOS on a craig 7" netbook clp218?
I have no idea about these craig things which are Android machines, Try this.
Cannot be worse than you got.
How to do a hard reset using external keys? If your tablet is completely locked up and you cannot access the menu functions, use the following method to perform a hard reset using external keys on your tablet:
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
If it doesn't work try search engines for 'Android tablet hard reset'
Sep 10, 2014 | Computers & Internet
What does it mean when android robot is laying on its back
I am giving you an example with an Motorola Tablet. I'd try clearing your cache partition, you can get to the android recovery with your buttons.
As you're going through the options don't do the factory data reset, look for wipe cache partition then follow the instructions to reboot.
Hope this helps!!! Let me know if you need more help
-Nadeem
Dec 25, 2012 | Ematic 7" eglide Pro Tablet
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Pandigital novel white stuck on blue screen
everytime i turn on my pandigital tablet it goes to blue screen and stays on there, until the battery dies, everytime you turn it on it goes to the blue screen and stay on there what should i do?
Mar 02, 2012 | PANDIGITAL Novel 7
My backflip is locked and i forgot my blur info , how do I reset/unlock my phone ?
  1. Power off the phone, press and hold camera button ( do not release), press power button until phone turns on.Release power button while holding camera button down.
  2. Release the camera button when prompted (following the Batwings boot screen).
  3. Press the volume down button and wait for 15 seconds for a "triangle !" to appear on the screen. ( message "volume up key pressed " will appear )
  4. With flip closed, tap bottom right corner of darkened display (just above back button).
  5. Select "wipe data / factory reset" on screen
  6. Press "Ok". Wait for "data wipe complete" message to appear
  7. Press "reboot system now"
  8. Press "Ok" . Phone will reboot and complete master reset function
Notes:
Dec 05, 2010 | Motorola Mobility Backflip Smartphone
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
