Question about HP Photosmart Premium C309A All-In-One Printer
THE PAPER IS BEING PULLED CROOKED INTO THE PRINTER
    Scholar:
  • 158 Answers
Make sure something hasnt fallen into the printer like a paper clip or something. I had that happen and was experiencing the same problem. Something very small can cause only one of the wheels to grab the paper causing it to pull in crooked.
If there is something in it just remove the papaer and gently turn the printer upside down and the foreign object should fall out.
Posted on Mar 13, 2011
Paper is pulled through crooked printing is not straight. how doyou clean the rollers?
This can be caused by several factors. It could be that there's something(like small foreign objects in the paper feed area) causing the paper to get crooked. It can also be caused by improperly adjusted paper guide or the paper is not in good condition.
Paper Feed Rollers Are Rolling But the Paper Is Not Feeding
How the Accu-feed Paper System Works
Mar 23, 2011 | Lexmark X75 All-In-One InkJet Printer
Prints crooked
The paper is not being pulled into the printer straight.
There are small sliders that rest next to the paper in the loading tray, you are required to push these so that they slide over and rest directly next to the stack of paper. This will guide the paper into the printer straight so that the paper does not get pulled in crooked.
Feb 28, 2011 | HP DeskJet 5550 InkJet Printer
The paper is being pulled in crooked every time
You might want to try using rubbing alcohol with a soft pad on the rollers near the ink cartridges...I've found that the ink can make the rollers 'sticky' and cause the paper to be pulled to one side. Hope this works for you!
Dec 09, 2010 | Canon MX300 Office All-In-One Printer
Paper is being fed through the printer crooked. Almost like the paper feed wheel is not working properly, being pulled down in the right side, but not on left = big mess
You probably have a piece of paper stick in the pickup carraige. Get a flshlight and a tweezers and see if you can CAREFULLY pull out any pieces of paper...
Feb 16, 2010 | Canon MP610 Photo All-In-One Printer
My paper keeps going in crooked and jams
Hi, at the following link you will find some easy to follow steps on how to prevent this type of problems. Also make sure there is nothing blocking the path of the paper when the printer is trying to feed it. Sometimes objects will fell inside the printer and block the paper path thus causing the paper to be pulled from one side and the other jamming.
http://bit.ly/duaUlt
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP C3150 Printer Continuing Paper Jam Errors
Sometime the ink jet mechnism is out of time or it gets stuck in the lock position. You might want to see if it looks like there crooked in the trays at the end of the printer.
Jul 04, 2008 | HP Photosmart C3150 Printer
G85 series prints crooked
From HP's site:
Problem: The print on the paper is skewed.
Solutions: 1. Slide the paper-width adjuster against the left side of the paper stack, and 2. make sure that the rear access door in the back is fully “locked”.
Jun 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Printing crooked
As "Guest" posted on Feb 05, 2009 the problem for me was the box in the back of the printer that facilitates double sided printing. One side had come loose. I was getting "Paper Mismatch" errors, and the text was printing slanted. I simply pulled the box out and reinstalled it. Problem solved.
Oct 25, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP Photosmart Premium C309A  All-In-One Printer Logo
141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
