Question about Whirlpool Washing Machines
Whirlpool AWO 3761 washing machine. When I turn tyhe machine on and the water starts to fill, sometimes it comes out of the drawer where the powder goes. I have to keep pressing the start/pause button until this stops.
What does it mean when fh comes up on washer
Posted on Apr 11, 2010
Spitting water
Turn the tap pressure down
Oct 05, 2017 | Whirlpool Washing Machines
Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Washing Machines
I have a awo 3761/5/s model and it keeps coming up on the display fh and the lights flash what does this mean
Unfortunately there are so many abriviations that one cant keep up.(not standardised). Best thing to do is do a manual check. Switch water off and check the filter. Clean it. Next, do a check and confirm that the drain pump is free of obstruction and free to turn.(loose). Get motor to spin by selecting spin and see if it does. If all those checks work out, it should function.
Jun 05, 2010 | Whirlpool Washing Machines
I have a whirlpool awo 3751 washing machine when i close the door set the program press the start button the machine appears to start and the time reduces but there is no water going to the machine i think...
You most probably have a faulty water inlet valve...Not an uncommon problem..They can sound ok, but when you check the detergent drawer there will only be a trickle..Replace the inlet valve...Good luck...Nomess
May 20, 2010 | Washing Machines
Soap dispenser blocking up on my whirlpool. awo/r5406?
take the drawer out and wash it top and bottom,then put warm water down the duct`s inside, if the water come`s back then the pipe is blocked,put a drop of pipe cleaner down.good luck
Nov 03, 2009 | Whirlpool Washing Machines
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
Whirlpool awo 3761/5/s
have you checked that there is not a blockage in the outlet pipe or that it is not kinked?sometimes if the pipe is lying to low (ie creating a u-bend) this can prevent water getting in & out & so the machine interprets it as either taps off or the pump needs cleaned (this has happened to me numerous times :) )
Nov 24, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
320 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
