Question about Car Audio & Video
I have been trying to pair my phone with the unit in my car so that I can use the bluetooth thats in my player. The units # is BC_HF_V01
SOURCE: Logitech HS04 V01 connection
Try turning off the headset. Then setting your phone to look for bluetooth device. Touch and hold for ten seconds the larger button on the headset, should flash blue light rapidly. then command phone to find device, (commands differ from one phone to another). When phone "finds" headset blue light should change to intermediate flashing (three flashes every five seconds aprox.) Hope this helps..
Posted on Aug 28, 2007
  • 504 Answers
SOURCE: default pin for pairing bluetooth
This varies unit to unit. Most generic codes are "0000" or sometimes, "1234", but it could be different. Which GPS device do you have?
Posted on Feb 23, 2008
Fixe_You
  • 1800 Answers
SOURCE: Pairing bluetooth headphone and mp3 player
search for devices option and visibility!! plz rate this post
Posted on Aug 25, 2008
SOURCE: Pioneer DEH-P700BT and Nokia N95
I managed to fix this issue with the auto disconnect using a Nokia N81 and Pioneer DEH-P7050BT.
I originally had the same issues that everyone else was facing, after trying several different things I successfully auto connect my phone when i turn on the ignition switch. It still disconnects when trying to download contacts, but i transferred these instead so not a big problem there.
OK so that steps i performed in order were.
1. Download and update the head unit software update from the Pioneer website, there is a link attached in another post. Follow the steps in the instruction manual.
2. Delete the pairing from the phone
3. Update the firmware of the phone via the Nokia Software Updater.
4. Turn off the PC Suit Sync in the phone, this can be found under settings.
5. Repaired the phone and the head unit, use the NOKIA-A option not NOKIA.
6. Authorise the phone to auto connect to this BT device without prompting.
This is all the steps I tried, some may or may not be usefull but after trying different combination's, I get a successful connection each and every time. A little icon of a car will appear on the phone stating it is connected.
I hope it works for you.
Posted on Nov 27, 2008
SOURCE: Can't figure out how to make my VR3 bluetooth unit send a signal to my BlackBerry.
Go here http://safemanuals.com/user-guide-instructions-owner-manual/VR3/VRBT200V-_E
Posted on Jun 03, 2009
Pin bluetooth code
you can find many codes on yahoo. just enter the search information with the model number of your devise .although it has also been my experience that the default code is 0000 "4" zero's
Aug 08, 2014 | 2009 Hyundai i30 1.6
Will my Nokia HF-33W plug-in car speaker kit pair with my new Nokia 2690 phone?
Yes it should pair without any problem, Bluetooth has a very stable standard not related to the model or brand.
Let me know if you need additional information or support.
regards
Mar 20, 2011 | Nokia Hf 33w Bluetooth Speaker Car Kit
Bluetooth connection not working. Tried with a couple of phones to find the player with no success.
Make sure that the mobile phone which you're trying to use is paired with the Car Audio System.
Check if the Blue-tooth icon at the front panel display is lit.
If the pairing is completed, try connecting the device to the head unit. Press and hold the BT button for 3 seconds to connect the mobile phone unit to the Car Audio system.
If the unit is not getting connected, then try to RESET the unit by pressing the Reset button located inside the front panel using a sharp pointed object. Once the unit is reset, try pairing the unit again and then connecting the devices.
You may also check the compatible Bluetooth devices with the Car Audio System.
Thanks for using FixYa.
Feb 15, 2011 | Sony MEXBT3800U Xplod Bluetooth for Car or...
My stereo system is showing HF error 68 and will not connect to my mobile phone. The system is a KDC BT50U
This error has nothing to do with installation - there is a bluetooth compatibility issue.
Not all bluetooth devices are compatible, and some only have limited functionality.
If you have already reset the unit, and the problem persists - the phone you are pairing is not compatible with the radio.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 12, 2010 | Kenwood Car Audio & Video
I need to know how to pair my phone to my c.d player
Turn the bluetooth on in ur phone.
Use MULTI-CONTROL to select
Connection open in the function menu.
Press MULTI-CONTROL to open the connection.
Always waiting is displayed. This unit is now
on standby for connection from Bluetooth
device(ur phone).
If your Bluetooth is set ready for
Bluetooth wireless connection, connection to
this unit will be automatically established.
Jul 04, 2010 | Pioneer DEH-P7900BT CD Player
Tring to install blutooth to my xdma7715 dual cd player
The Dual XDMA7715 unit does require a separate module called the Dual BTM60, as technically the XDMA7715 is a "Bluetooth Ready" cd player.
Assuming you have bought this module, the next thing you need to do is 'Pair it" with your mobile device, which I will assume is your cell phone. This keeps it from connecting with other people's cell phones as they drive by your car.
Before you begin, you need to prepare your phone for paring. Check your cell phone's users manual if these instructions don't apply, but generally this means you find the Bluetooth menu on your phone, turn bluetooth on, and make the phone 'visible' which means your stereo will be able to see it in order to pair up with it. Usually, turning visibility on only lasts for about 30 seconds, so you may have to try this more than once to get the timing done right. Once paired, you won't need to turn the phones visibility on again until the next time you pair a device.
Now that your cell phone is ready to pair with the stereo,
1) Press the Phone symbol on the cd player or the BTM60, pr press MODE until 'DUAL_BTM60" is displayed.
2) Press and hold the phone symbol on the cd player or the BTM60 for 5 seconds, until "PAIRING" is displayed. The Bluetooth icon will flash every second. The Cd player will broadcast its "availability" for 60 seconds.
3) Complete the pairing from the Bluetooth menu of your cellphone by selecting "Search for new devices". When they find each other, the Bluetooth icon will illuminate solid, and your phone will say it has found device "DUAL_BTM60", and ask you for a password to pair it.
The BTM60 device name is "DUAL_BTM60".
The password you enter into your phone to accept the pairing is "1234"
Now that the devices are paired, you should be able to make calls handsfree, and play music stored on your phone.
I hope that helps.
Nov 24, 2009 | Dual Car Audio & Video
Old phone would pair with Clarion VRX785BT's bluetooth
you auto connect is turning off on the screen. try keeping ur phone permantley visable.
Jan 10, 2009 | Clarion VRX785BT Car DVD Player
How do you pair an LG Dare phone Bluetooth to Pioneer Avic Dz3 unit
make sure your phone is in discovery mode so it can be seen by bluethooth device, I had the same problem with my lg voyager
Aug 12, 2008 | Pioneer AVIC-D3 Car DVD Player
May 08, 2007 | Logitech (980408) Wireless Headset
Car Audio & Video Logo
197 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
