SOURCE: electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
SOURCE: Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
SOURCE: Frigidaire Model FEFL78CSA oven not heating
I apologize for not getting back to you sooner. I tried to respond to your question yesterday, but the web link was not working. Your assumptions are probably correct as the ERC controls all the oven features on an electric range. This is a fairly simple repair job that any do-it-yourselfer can accomplish.
The ERC is easily accessed by removing the back panel of the operator console. The circuit board is screwed in place with a series of wire connectors. Most models have the wire color coding printed on the circuit board for ease of identification. In addition, there should be a wiring diagram located either inside the console, or on the back of the range. This will also list the color codes. If not, I would recommend you label all wiring BEFORE removing to ensure everything is reconnected correctly (a digital camera can come in handy as well).
New ERCs generally do not come with the overlay. This is the plastic printed face-piece that covers the front of the board with all your controls and numbers. Some manufacturers provide this with the new ERC, but MOST do not. The existing one can be reused by carefully removing and reinstalling to the new ERC. You may consider ordering an overlay too if yours is in bad shape.
You can order a replacement at searspartsdirect.com. Pcappliancerepair.com also carries the part for just a few cents cheaper. I recommend the sears website for the helpful exploded view illustrations. Just type in your model number and look under the "Backguard" heading for item number 20 (part #316207529). The overlay is listed as item 20A (part #316220804). If you wish to save a little and order from the other website, use the part numbers provided by Sears for your search criteria as I could not find your model number listed.
Please ensure you UNPLUG the appliance before servicing. No special tools are required. If you have questions, please post back and let me know. I hope this helps you.
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
SOURCE: I have a Viking double
Click this link directly to get full disassembly diagrams.If lower door is closed,then lower unit has to be disassembled,if upper door is got locked,then upper section has to be disassembled. Click this link directly to get section by section disassembly diagrams:--- http://technoanswers.blogspot.com/2011/01/how-to-disassemble-viking-electric.html ------------------ If the diagrams are not very clear then check out this links one by one for proper view:-- Link for control panel:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00001.png ------------- Link for door latch:-- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00005.png ---------- Link for door disassembly:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00006.png ------------- Link for cabinet disassembly:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00002.png -------------------------- This should help.keep updated.Thanks.Helpmech.
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
