Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619
We lost the instructions to reprogram our Schage lock. can you help
  • 963 Answers
Installation and programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
You will need Adobe Reader installed on your computer, as this is a PDF file.
Posted on Mar 17, 2011
Schage lock
Is it lined up fully? Cables loose?
Jun 30, 2013 | Locks & Locksmithing
Schlage locks
Have you tried taking the lockset apart and checking to see if you have a loose connection or maybe a pinched wire? Most electronic locks have sensitive wiring. Check that and see if that's the problem. If connectors loose then tighten it back up. If a pinch in the wire let me know. I'll help as much as I can.
Lost combination
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Change the batteries with fresh brand-name batteries before you reprogram!
Sep 21, 2012 | Weiser Lock Powerbolt 1000 Lock
Need to change lock code but lost instructions. BE365 PLY 716
Reprogramming BE 365:
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
May 21, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
I lost the manual and i need to reprogram the codes
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
There is a video on this page, showing how to change codes.
Jan 22, 2011 | Schlage Electronic Lock FE595 Plymouth or...
I have a 4 digit schlage keyless lock and want to reprogram it
There's a video for reprogramming it.
Dec 20, 2010 | Schlage Locks & Locksmithing
I have lost the instructions to program the powerlock by weiser i need a copy of the setup the code where can i obtain this?
Here's a link which tells you how to remove the cover, and reprogram the lock codes:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Jan 17, 2010 | Weiser Lock Powerbolt 1000 Lock
I can't find my key code card to my lock: MFG
Rather than list all the steps, which get lengthy when typing them step-by-step, I'll provide you with a weblink to the Schlage web site that has both pdf's and videos showing you how to re-program and operate your lock set. You can download the instructions to print and save for future reference too.
As you've forgotten/lost your master code, you'll need to use the restoring instructions to reset your lock to the factory default settings, so you can then reprogram new codes into your lock.
Basically, you'll need to open up the inside compartment and push the reset pin/button in order to clear all current code programs and then start over with inputing new codes, etc. Have your key with you, as you'll need it in case you accidently lock yourself out, while reprogramming the lockset.
http://consumer.schlage.com/customerservice/FE595_install_inst.asp
Hope you find this Very Helpful - Best regards!
Aug 12, 2009 | Schlage BE365-PLY BE365PLY626 Satin...
Lost key
Get out your wallet and go to the dealer! Not much else you can do. Those keys have imbeded security chips that must be programed by thr dealer.
Jun 16, 2009 | 2006 Chevrolet Equinox
Zero halliburton triple combination lock instructions manual
Depress the square release button, just to the right of the 3 dials on outside of the case, while providing an upward pressure on the small tab on the inside of the case just behind the 3 dials. Now select your new combination by selecting new digits for each dial.
Dec 15, 2008 | Cameras
Schlage Camelot Deadbolt Keypad, Satin Nickel #BE365VCAM619 Logo
105 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
