Question about Toshiba Computers & Internet
I HAVE A PROBLEM WHEN TO AJUSMENT A SCREEN RESOLUTION & NOW IS COMPLITY BLACK SCREEN
  • 55 Answers
In order to restore your resolution to one that can be displayed by your monitor, you need to restart the computer and enter Safe Mode. To do that, press the F8 key right before the Windows logo shows up during boot (just keep pressing it until you get it).
It should show a menu, from where you must choose to boot in "Safe Mode".
After Windows loads up in Safe Mode, just open the screen resolution settings (right click on the desktop, select Properties) and select 800x600. Click on OK.
Now restart the computer normally and let it boot into Windows. You should be able to see and change the resolution (using the same method mentioned above) to any desired.
Hope that helps!
Posted on Mar 13, 2011
Black screen when windows starts to load
u should be more specific my freind but as i understand that it is a problem of resolution or refresh rate so boot the pc with another monitor & try to change the resolution & refresh rate to a desirable for ur lcd
Jan 14, 2013 | Sansui Hdlcd1955w
Is Nvidia Geforce 210 compatible with AOC e1620Swb monitor?
Hello i guees you have to uprade your graphic driver
with the newest one.
This is the drver for XP:
http://www.geforce.com/drivers/results/49741
And this is for windows 7 64 bit:
http://www.geforce.com/drivers/results/49949
If other drivers needed:
Remember to uninstall the old one before you install the new one.
Try also to check the screen resolution on the screen
set it to factory settings.
But the game resolution could also have been set to high
when this happens you get a black screen.
Good luck
Nov 02, 2012 | AOC Computers & Internet
I have a p5gcmx problem, displays black after installing the window7 os
ASUS P5GC-MX - O/S Compatibility - Link
Windows Vista
Windows XP
Windows 2000
Options you can try.
1. Can you boot the OS Win 7 in "Safe-Mode"?
If you can boot your system into safe-mode, then your monitor cannot handle a "higher graphic resolution" which will result a black screen. You can try using a better montor with resolution "1280x720".
Hope it helps, & Good luck.
Mar 03, 2011 | Computers & Internet
Displays 'Input Not Supported' at start up om black screen
Seems that you have set the resolution on your graphics card to a setting higher than the maximum resolution supported by your monitor.
Try to boot into Safe Mode & lower the resolution of your graphics card. If not possible, go to Device Manager & remove the graphics card from it, then reboot your computer. This will reset the resolution.
You can then re-install your graphics card drivers & get it to work properly.
Sep 20, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
My monitor goes blank after a while,power light still on,why is this & what can I do?
Check connection cable with videocard on your PC, unplug it and carefully plug it in again. (Turn off your monitor during this operation). If monitor goes black after loading OS (like Windows), then your screen resolution higher then monitor can support. Load computer in Safe Mode and lower screen resolution.
Aug 10, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen resolution change = black border around small screen
RIGTH CLICK THEN DISCKTOP THEN PROPERTIES,DESPLAY AD SETTING, CHANGE INTO 1024 BY 768 PEXILS.... TO FIT THE SCREEN RESOLUTION 32BIT ONLY
Jun 04, 2009 | Dell Inspiron 8200 Notebook
Black screen with box of 'Suggested resolution 1280 x 1040 60Hz'
The Samtron 73V has a maximum resolution of 1280*1024, are you running at that resolution ?
Mar 15, 2009 | Computers & Internet
Screen resolution
The correct resolution is probably 1440x900. iF it is at that resolution, then tell me is the black part on all sides of the picture on just on side or the other of the picture???
Dec 26, 2007 | Gateway 6525GP Notebook
C840 resolution difficulties...
The type of screen you have is a UXGA screen. the optimal resolution for that is 1600 x 1200. changing the resolution for that will distort the screen causing black borders. If a computer has a 15.0+" SXGA+ screen with an optimized resolution of 1400x1050 and the screen's current resolution is set to 1280x1024 pixels, the display will shrink resulting in a black border surrounding the edges of the screen. Also, all other lower resolutions may be stretched to fit the screen. No border will be visible, but fonts may appear slightly fuzzy.
Oct 03, 2007 | Dell Inspiron 8200 Latitude C840 Laptop...
Computers & Internet Logo
29 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
