Question about Sport & Outdoor - Others
White schwinn airdyne bike serial number placement and age can't find.
  • 3567 Answers
SOURCE: Looking to find age of yamaha bike using serial number
Get the vin number off the front downtube that the steering triple tree mounts to. Call a Yamaha dealer with the vin # and they can tell the year, engine size and model of bike.
Please rate this solution.
Posted on Mar 30, 2009
SOURCE: battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Posted on Apr 23, 2009
  • 990 Answers
SOURCE: Need users manual for old Schwinn Airdyne - analog model
Sheldon Brown's Bicycle glossery is a good place to start, you can google him and he may be slow on replys but he can usally steer you in the right direction.
Posted on Aug 21, 2009
Testimonial: "I emailed Sheldon Brown. Larry"
  • 49 Answers
SOURCE: Owner's manual for older Schwinn Airdyne
http://support.nautilus.com/support/schwinn/uprightbikes/prdcdovr~3550012/Schwinn+Airdyne+Exercise+Bike.jsp
Follow this link and you can download the owners manual as well as the exploded parts schematics. There will be information about the different years. other than the consoles they have remained the same for 20 + years. If you ever need to replace the bottom bearing be sure to get the lock ring as well. It changed from left hand thread to right. Thats it. You can also upgrade the console to the newer version. A little expensive but with proper care a 20 year old Airdyne will last till the frame rusts out from under it.
Posted on Sep 01, 2009
terpcafe
  • 16 Answers
SOURCE: I need to tighten the chian on my schwinn airdyne.
Two places to tighten the chain and it requires you to loosen the nuts on BOTH sides of the bike, almost at the same time. Start at the fan wheel (top) of the bike. First thing you need to do is to loosen the little nut at the hub of the fan wheel on both sides. Unscrew it almost to the point of taking it off, but leave it screwed on the end of the bolt so it will stay on the bike. Then use an adjustable wrench to loosen the nut a bit on one side and then do the same on the other side OR use both hands and loosen both at the same time by unscrewing with adjustable wrench in opposite directions on both sides. Once the wheel is loose, you want to sit in front of the bike and pull both of the large nuts at the same time toward you and the chain will tighten. The goal is to have the fan wheel centered and for you to be able to see about 1/4" inch of clear gap behind the nut on both sides. Then use your fingers to tighten the nuts to the frame just enough until you can use the adjustable wrench again. I have sometimes used a flat head screwdriver to insert into the gaps to prevent the chain from loosening up. The tighten the nut on both sides of the bike. Be sure you tighten the little nuts as well (they are called chain tensioners). That SHOULD do the trick. However, if your bike chain is still too loose, you need to do the same for the chain at the pedal area, That requires the same thing all over again, but in most cases, the chain loosens at the top part of the bike (fan wheel place). However, if you do work on the pedal area, you want the chain to be pushed toward the fan and not toward the **** side of the bike. It may sound crazy but that's the only way to tighten the chain. give me a thumbs up with my solution.
Posted on Jun 06, 2011
Recently purchased a used 2008 Airdyne, serial #0906G00228, can you tell me the model number with this information?
I assume that you posted this in the wrong category and are asking about an exerciser bikes.
Airdynes are a product of Schwinn. Below is a link to their products and manual pages.
J
Schwinn Product Manuals
Feb 20, 2018 | Cell Phones
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Need manual for schwinn Airdyne Upright Cardio Exercise Bike, Older, i have a picture if needed
You need to do some simple research rather than ask others to do so with inadequate info. Google manual schwinn Airdyne Upright Cardio Exercise Bike.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Dec 14, 2016 | Schwinn Cycling
User Guide/Manual for Schwinn Airdyne AD3
Schwinn Fitness has many of their manuals here: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . The direct link to the owner's manual for all Airdyne exercise bikes is available here: http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_Airdyne_Evolution_OM_web.pdf . If you need the assembly directions, see the Airdyne AD4 guide: http://download.nautilus.com/supportdocs/AM/Schwinn/SCH.Airdyne.AD4.AM.EN.pdf . The AD3 and AD4 are very similar.
I hope this helps.
Apr 08, 2015 | Schwinn Cycling
My computer on my Schwinn Airdyne's numbers are only half showing. Is it low ink
the displays use LCD in the display not ink it sounds like the battery(s) are low see about replacing them and the display should return to normal if the batteries are new the display might be damaged due to age, heat, or physical contact with the display i.e. pressing the display, hitting it, something fell on it
Jun 04, 2014 | Schwinn Original Airdyne
I Need Console for 1988 Airdyne
The age of the machine is not as big of a replacement parts hinder as is Schwinn going through so many buy outs since 1988.
One of the best exercise repair parts on online is FitnessRepairParts.com. They have consoles which are similar to your generation of machine for 170.00 - 240.00
Otherwise schwinn was most recently owned by Nautilus/Bowflex/LAMAR fitness and they may be able to help through their website.
Sorry, I don't have a great source of imformation to help with. I repair Schwinn exercise and it has become very hard to find parts recently as the new generation of AEROdynes are very different. Although, up until maybe 1-2 years ago, nothing had changed for 30 years.
Alternatively, search craigslist and ebay. You may have to buy an entire unit to get the part you desire. Often they have a drive mechanism worn out which devalues them to the seller, but has minimal to do with your search.
Good Luck.
Jan 06, 2013 | Schwinn Airdyne Ad4 Upright Bike
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
Jul 11, 2012 | Schwinn Airdyne Ad4 Upright Bike
I have an older (25+years) Schwinn airdyne bike. The mchanism on the front wheel hub that drives the cable to the speedometer is not working. As a result, cable not driven and no load or speed...
How about going to a Schwinn dealer who has been in business for a long time? The speedometer drivers are no longer available, you have to get it changed over to electronic. This not something that you can do on your own, it has to be done by someone who knows the product. We have been in business 40+ years and sold Air Dynes since 1979, I do know what I am saying.
Jan 23, 2011 | Schwinn Original Airdyne
Apr 23, 2009 | Schwinn 430 Elliptical Trainer
Sport & Outdoor - Others Logo
255 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
