Question about Ovens
We had the oven on 400 degrees for about 30 minutes. All of a sudden it started making a continuous high pitched noise like a smoke alarm. I turned off the electric and the noise SLOWLY faded and finally stopped.
IF IT'S A CONVECTION OVEN, IT JUST MIGHT BE A FAN PROBLEM. THE BEARING MAY BE GONE OR SOMETHING IS LOOSE AND TOUCHING THE FAN.
Posted on Mar 13, 2011
I set my brand new GE oven to bake and it almost immediately started to smoke. It continued to smoke even after I turned it off. It smelled like burning wood. It kept smoking (15 minutes) until I unplugged...
Wherever you bought it from should have a warranty. Get them out there to look at it. The smell of burning wood is odd. Check to make sure all of the packing material was removed prior to installation. That could be burning cardboard on the outer casing of the oven.
Dec 18, 2014 | Ovens
Top oven turns on by itself.
this is usually a thrmostat fault
Feb 04, 2018 | GE JKP27 Electric Double Oven
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Oven will not heat until you turn the heat up to 400 degrees
Your "Bake" element may not be working properly. It's the one in the bottom of the oven. Place a couple drops of vegetable oil on the bottom pan, and turn the oven on. During pre-heat, you should start to see those oil drops generate some smoke, IF the lower element is working properly. If it isn't - voila'.!! Problem is with the lower element / associated circuit.
Oct 02, 2009 | Amana AOCS3040SS Electric Single Oven
Kitchen Aid Double Convection Oven blows circuit breaker
the kehc359jss mircowave won't start, it says "door" on the display but the door is closed.
Feb 19, 2009 | KitchenAid Architect Series KEMC308KSS...
NEFF OVEN PROBLEM - SMOKE AND FUMES COMING OUT OF OVEN
Take the cover off that is surrounding the fan and you will probably find food or something there or on the fan blades. If it is not a food smell, then there is probably some wiring that is burning. I suspect that there is food behind the housing of the fan.
Feb 02, 2009 | Ovens
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
Temperature in oven is way off
Jim,
A couple of questions... What makes you think the oven is off that far? If you have a set on the shelf dial type thermometer, throw it away. They are never accurate and generally read 50+ degree too low. I recommend the "biscuit test". Which is simply a cheap can of "hit on the edge of a counter top to open" biscuits and see how they bake with the instructions on the can. Make sure you allow the oven to preheat for 20-30 minutes (always but especially for this test).
To change the oven setting press BAKE, then run the temp up to 550 then immediately press and hold the bake pad for 10-20 seconds. The display should read 0 (zero) you can then use the up down arrow pads to adjust, hit bake pad again and then "clear" when done to lock it in but, you can only go up or down 35 degrees. If it is truly off by more than that you would need to change the main oven control board and oven sensor.
Dec 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Ovens Logo
314 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
