Question about HP Pavilion F70 17" Flat Panel LCD Monitor
Hp pavilion f70 monitor turns white. when i turn it off and back on with the monitor power buttom the video returns but goes off again after a few munutes.
    Novelist:
  • 134 Answers
Verify that it's the monitor and not the computer by hooking another monitor to the computer and observing the results. If it's your Hp f70 that is the problem, then something in it is going out, like the inverter or perhaps a loose connection. If you don't want to open the monitor and have a look-see for yourself you can always take it to a shop to have it checked out.
Posted on Mar 13, 2011
HP LP3065 monitor turns off and won't turn back on; is this a Windows problem
It doesnt sound like a windows problem. A simple test for this is to unplug the vga or hdmi cable from the monitor then turn it on if it has power it should say no signal. Also try either another power cable to the monitor or change the fuse. Hope this helps.
Oct 19, 2012 | HP LP3065 Monitor
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
How do you disassemble the hp pavilion f70 monitor? The monitor does not light up and I think it's the backlight.
plumldk1, Watch some video clips of "LCD monitor disassembly" at youtube. Yes, parting the rear cover from the front plastic bezel is the hardest thing to do!!!! Also visit www.ccl-la.com/badcaps.htm. You might see some tricks to help get the thing apart. Are you positively certain that it's the "backlight" and not the "electronic ballast" that has failed? Will you find any swollen electrolytic filter capacitors on the SMPS board? 12fixlouie
Jan 17, 2010 | HP Pavilion F70 17" Flat Panel LCD Monitor
My hp pavilion f70 flat panel lcd monitor comes on and works fine with a beautiful picture...for about 1/3 of a second. then it goes blank. any ideas how i can fix this or what might be wrong?
Hi:
The symptoms you describe, pretty much diagnose a failed High Voltage power supply board problem in the monitor. This is usually cost prohibitive to repair, as LCD monitor prices have dropped a bit, so your monitor is beyond economical repair.
Nov 30, 2009 | HP Pavilion F70 17" Flat Panel LCD Monitor
Screen goes black on my hp pavilion dv4000 notebook
Try connecting an external monitor to the laptop, power up the monitor first then boot up the laptop. The video data will switch to the monitor automatically, check if the monitor dislays a normal image and see if the image stays on the monitor.
Also press and hold the Fn key and press the F4 key, these keys toggle the video output between the LCD screen and the video port.
Test to see if this functions correctly.
Get back to me with the results of the tests.
Jun 03, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion meets monitor
I would fathom a guess that the motherboard has been damaged, if it is the PS then you can see by taking it into a service center to have the output checked 3 v 5 v 12 volt good luck.
May 26, 2008 | HP w19 19" LCD Monitor
Going to Sleep
got the same issue
hp pavilion 1723
Nov 01, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Pavilion f70 monitor has dislodged on/off button
Nor would they. If you cannot see how to open it up then U suggest the item is a snap together shell and best left alone. If it is on all the time and the wall plug inconvenient- cut the power cord[unplugged of course] and insert an inline light switch- some times called a torpedo switch. Any electrical store will have them.
May 20, 2007 | HP Pavilion F70 17" Flat Panel LCD Monitor
HP Pavilion F70 17" Flat Panel LCD Monitor Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
