Question about Bush Televison & Video
Lcd tv my bush 32' tv turns its self of after a short time then i have to wait for 5-10 mins before i can turn it on again
I've brought a 32"bush lcd tv from Argos yesterday and the picture went off but the sound never
Tried turning it off but no change what is the problem
Posted on Jun 07, 2012
    New Friend:
  • 50 Answers
If you dont have the knowledge in troubleshooting you must refer it to the technician near your place because there is problem in the power supply section or there are some components that overheat and the protection system shut down the tv automatically.
Posted on Aug 01, 2008
32 in proscan lcd tv just turned on tv and colours were all distorted
Try hard reset, unplug TV, wait 10 min. and plug back in.
. You may have to reset your setup configuration back to how you preferred. hope this works for you
Jan 14, 2016 | Proscan 32LB30QD 32 in. LCD TV
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
Westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
Mar 23, 2010 | Westinghouse 32" Flat Panel LCD HDTV
Soyo Tv keeps on turning self off.
Call your manufacturer if you are still under man. war. they can replace/repair the unit for you if not they can give you some referrals. Sounds like your powerboard is going to go out on the unit.
Aug 07, 2009 | Soyo DYLT032D 32 in. LCD Television
32"ASTAR problem
Please call 323-767-6030 and I will trying to help you as much as I can for the astar ltv-3201 tv.
Jan 30, 2009 | Astar LTV-3201 32 in. LCD Television
Setting the clock on the lcd32-09
Try to umplug the tv from the power. Run the autochannel search again. The tv pick up the clock signal from your cable provider.
Regards cala
Jan 02, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Samsung le32r74bdx 32
i have a $1256 samsung 40'' lcd i have had it for about 1.5 years..just long enough for the warranty to expire..i went to turn the tv on like nomal but all i got was a ed blinking light..and than it would go out after the relay inside clicked a few times.tryed all the to fix it my self..new power cord,diffrent outlet,letting it sit unpluged for 24hrs.ect..finally i took it off the wall took the back off to see if any fusses were blown out. nothing it all looked good to me.so i took my air commpeser to it and blew the whole thing out..put it all back together..and it turned on red light was off and just a hint of light at the edge of the screen...so i was like ok and began to play my ps3 and after about 45 min i just shut off ..nothin would work back to the blinking ed light.i have not messed with it for 3 weeks and yesterday tryed it again.nothin but relay click and red light...so i hit my tv at the bottom by the switch and i came on...i couldnt believe my eyes..it was short lived after watching it for 5 hrs tuned it off and went to bed...in the morning i ran down stairs to turn on my tv..but yet again black..i was not going to spend $300 to $700 to get it fixed..so to day i got my air commpeser and blew it out again..this time i was messing with the power cord right where is hooks to the tv and the red light stayed on solid like it was in stand-by so i pressed the power button and it turned on..so long story..check the power cord and blow out you tv.."but be carful"
Aug 09, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Sony KV32s22
Hi: Sounds like it might be an overheating part, and the short is shutting of the set. Or it could be an intermittent connection in the pc board. Either case it would have to be repaired by a expert.
sorry.
Mar 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
LG 42lc7d 42" lcd
Replace power supply and this should take care of all of you problems part number is EAY34797001.
Josh
Feb 09, 2008 | LG RZ-20LA70 20 in. LCD Television
Televison & Video Logo
497 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
