Question about Smeg CSU2007 Built-in Dishwasher
We just accidentally used liquid dishwashing soap in our smeg csu2007 dishwasher. Tons of bubbles now. Web searches indicate that we should spray with salt and force into a drain cycle to eliminate the bubbles. Which cycle - 1, 2, 3 or 4 - will be the best to choose?
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
SOURCE: Smeg dishwasher
Hi, You can download SMEG dishwasher manuals from here: http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN Al.
Posted on Feb 10, 2007
Noggin
  • 944 Answers
SOURCE: Error message on Smeg dishwasher
Sorry couldn't find the info online - try these guys, they are the official smeg service agentsm and they have a live chat feature too -perhaps you get lucky and they will tell you the problem; http://www.smeg-service.co.uk/ Hope this helps - if you get no luck from them then please post again :)
Posted on Apr 23, 2007
  • 1462 Answers
SOURCE: E2 error in smeg dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Posted on Nov 20, 2008
  • 120 Answers
SOURCE: Smeg integrated dishwasher continually washing -
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Posted on Nov 03, 2009
Excessive bubbling
You should never see soap bubbles in a dishwasher, to get rid of the sudsing you need to take a couple tablespoons of vegetable oil and run through the dishwasher on pots and pans cycle, sounds like some regular dish soap accidentally got into the dishwasher, you may have to do several times depending on how much bubbles you have.
Jan 24, 2014 | Miele G 2670 SCVi 24 in Builtin Dishwasher
Smeg DI 409CA Dishwasher - Doesn't wash properly, tablet doesn't desolve and cycle lasted all night
The first thing is have a look at the instruction manual from HERE
If the dishwasher is not washing properly then please follow these steps:
  1. Check the water temperature. Should be 125 to 140 F.
  2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
  3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
  4. Check the spray arm and pump cover for splits or leaks.
  5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
  6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
  7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
As you said that the water builds up at the bottom see If it comes out 'foamy' then liquid dish soap is getting introduced into the dishwasher. Liquid dish soap is different than automatic dishwasher detergent. liquid dish soap needs to be COMPLETELY rinsed from anything that has been pre-soaked prior to putting in the dishwasher. after a couple of regular cycles the foam will go away. Nowadays liquid dish soap is also 'concentrated' or 'ultra concentrated' which doesn't help.
If further this does not solve your problem the the only solution is to get it repaired.
Goodluck..
Feb 23, 2008 | Dishwashers
18 month old kitchen aid kudc10fxss leaks water at bottom of door
Someone may've accidentally put liquid dishsoap rather than dishwasher soap into the fill cup. The bubbling will cause lots of foam to rise up above the float-switch without actually raising the switch (shutting off the water supply). Lots of helpers on the web recommended draining, wiping out the foam, pouring in a cup of vinegar and a handful of salt and running the rinse cycle a couple of times. It worked for me!
Feb 25, 2013 | KitchenAid KUDC10FXSS - KitchenAidR...
My son used liquid dish soap in the dishwasher - what do I do? The bottom of the dishwasher is completely full of soap and bubbles. Thank you
Takes some towels and carefully soak up the soap. There is a heating element inside the dishwasher so you don't want to be rough.
Apr 18, 2011 | Whirlpool Dishwashers
Extra suds due to liquid soap in the machine overflowing. How do I drain it?
This is strange. Are you using an electric dishwasher liquid soap, OR are you using a dish soap that you manually use to wash dishes?
REGULAR dish soap liquid that is not specifically made for dishwashers creates a foamy suds with lots of bubbles that will in fact bubble out of your dishwasher. on the other hand. Electric Dishwasher detergent will NOT create foamy suds with lots of bubbles.
Switch your soap. The next cycle any residue suds or soap will be gone as long as you use the proper liquid detergent. I would also recommend using a rinse agent which further helps break down and rinse off residue.
Mar 18, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Liquid soap mistakenly used - bubble explosion
Fill the detergent cup with fabric softener for a full cycle. Don't be alarmed if bubbles seep out.
Finish off with a white vinegar wipedown of the insides if it still feels soapy.
Sep 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch dishwasher, dishwashing liquid caused bubbles everywhere
clear the error then run the unit several times without any soap at all -- this should clear up the problem.
Sep 02, 2009 | Bosch Dishwashers
Dishwashing liquid was placed in the jetdry compartment
hi thanks for the question no its not ruined . just keep filling using vinegar , that will cut down the suds .do it 3 or 4 times problem will go away thanks the appliance doc
Sep 27, 2008 | Hotpoint 23 in. BF41 Built-in Dishwasher
I have a kenmore dishwasher. the soap dispenser lid was not opening and releasing the soap, now the lid is opening but it's leaving the soap in the dipenser. have used the pellets that contains the liquid...
disasemble the pump housing and remove the debris that are located in the housing, not enough pump pressure to spin the spray arms to desolve the detergent
Apr 09, 2008 | Dishwashers
Continuous rinsing
Put 2 tablespoons of oil into the water at the bottom of the dishwasher it will help break up the suds. Sprinkle as well ordinary table salt liberally across the suds to disperse them. Try to drain the unit as much as possible, soaking up any residual water or suds with a dry towel. Let the machine fill again, and repeat the process if necessary. Good luck !
May 25, 2006 | Hotpoint 23 in. BF41 Built-in Dishwasher
Smeg CSU2007 Built-in Dishwasher Logo
21 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
