Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Will not play tape - Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
    Genius:
  • 1,812 Answers
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Mar 15, 2011
The menu screen displays but it wont play tapes
Do the tapes play in the machine, but you don't get a picture. Or do they not even start to play?
If they play and you don't see a picture then you need to clean the VCR head. You can get a tape head cleaning tape for this.
If the VCR won't play a tape at all, please describe in more detail what happens when you insert a tape for playback and I or someone else at Fixya will help you further.
Nov 16, 2015 | Zenith Televison & Video
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Vhs view block
It sounds to me like you have a blank tape or an SVHS tape, which won't play on a VHS machine though they look the same tape.
Jan 25, 2013 | Televison & Video
I have a onkyo cassette tape deck ta 2600,when you push play on the cassette,it would play the tape for half of a second and stop
Sounds like the cassette tape itself is too tight to play, try fast forwarding or rewinding the tape in the deck all the way to the end of tape several times before trying to play. This may solve the problem
Dec 27, 2010 | Onkyo Audio Players & Recorders
Some of my Hi8 tapes play in fastforward motion along with the audio, but the other tapes play just fine. What can I do?
Clean the header of your camera. Buy a different camera to play those tapes. Try looking for a tape cleaner and tape lubrificant. Some tapes go so dry and overheat while playing on your camera that they end up on a blue screen and only play on FF and most of times not even that.
A good advice is to keep your tape cold, camera cold and try again.
Dont heat your tapes.
Also try battery playback, so it does not over heat with the power supply on.
Oct 01, 2010 | Samsung Electronics - Others
Playing Tape to End Requires Head Cleaning Every Time
it seems your tracking needs to be looked at.also have a look at the tape open front section button at side slide open with your finger.look at the tape toward the light,if the edge of the tape is a bit wavey not straight you will need an alighnment as well.
Apr 26, 2010 | Sony DSR-11 DV / Mini DV VCR
Sony dv premium ME DVM60 Mini DV tape. How many times(hr) to use
Recommend contacting your local service provider directly or online here:
Contact Us
Jul 29, 2017 | Canon Sony DVM-60 Min. miniDV tape - 6Pack...
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
18 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
