Question about HP PSC 2355 All-In-One InkJet Printer
Hp psc2355 the problem is that my printer keeps on sayin paperjam,press ok and it keeps doing this over and over again with all the files I try to print. I did reset the printer and still it goes on, i even can't print the line out forms. HP can not give me a solution either. Help would be greatly appreciated. Ren?
  • FETTI333 Aug 08, 2008
    MY PRINTER KEEPS RESPONDING SAYING PAPER JAM AND THERES IS NOTHING IN IT
  • leonard8899 May 17, 2009
    keeps repeating paper jam. Defintely no paper in printer
    HELP
My HP PSC 2355 will not feed paper into the printer and even when there is plenty of paper it keeps saying the printer is out of paper. Can someone tell me what is up?
Posted on Jan 23, 2009
  • 446 Answers
It could be somehow i think there is still a presence of paper on the printer, the sensor that senses the jamming mode was somehow interrupted or tripped, ( even if ther is no paper) if you could check this again and find out it would be helpul to identify what causes your problem.
cancel all docs on your PC also
hope this helps
Posted on Aug 01, 2008
I have an HP C4680..After a paperjam I am unable to print black and white. Copy comes out a very light green, almost unreadalbe...any suggenstions
Sometimes the Paperjam can cause the print heads to mis-align. Pull out the cartridges, turn the printer off. wait 2 mins or so, turn the printer back on, replace the cartridges and try again. Also ink can build up on the print heads, causing print quality issues. See this link to clear it up. http://www.fixya.com/support/r3986425-unblock_print_heads
Regards GM
Apr 05, 2011 | HP Photosmart C6380 All-In-One InkJet...
Our HP Officejet Pro L7780 All-in-One have had a paperjam. I have removed all the paper, but the printer shows the whole time there's a paperjam again. The printer makes a sound when you turn on the...
Try unplugging the power cord of the printer from the back of it while it's turned on and then plug it back in.
If you still gave the message try pressing ok and see if you get rid of it.
Here are some work arounds for that issue:*Try removing and reinserting the cartridges and make sure they are properly fitted in. *Remove and reinsert the duplexer *Try cleaning the rollers infront of the printer and from the back of the printer. *As for the rollers try, moving them and turn them around with your fingers. *Turn the power off and then on
This is a hardware issue already so if all else fails for your printer. It's better to just call tech support. If the printer is in warranty they will be able to replace it. If it isn't they might let you in on a good deal.
Feb 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I have hp deskjet 2300d showing that their is a paperjam. I found no paperjam what do i do
There is a line of sensors along the paper path, if any of these are obscured by even the smallest scrap of paper you will get the messasge, re check the paper path again it only needs a scrap of paper, if you can spot any of the sensors give them a blow with some compressed air (paper dust build up), last but worth a try unplug for 2 minutes to allow residual power to drain and then try power up and see if the message has cleared
Sep 09, 2009 | HP LaserJet 2300d Printer
HP 1320 will not print
hi..
what about the ink levels...open the backdoor of the machine and check for any obstacle....disconnect all the cables..press and hold down the power button for 30 sec..reconnect all cables..try again...try connecting the machine directly to the walljack.
Nov 25, 2008 | HP LaserJet 1320 Printer
Region Changin
To change the country/region, you must first set the default language again.
You will have more info here: (your printer manual)
http://www.viking-direct.co.uk/speciallinks/gb/vkg/source/psc2355.pdf
Oct 07, 2008 | HP PSC 2350 All-In-One InkJet Printer
DCP-130c error 44 Please Help
error 44 dcp 130/mfc 240/440 etc.:
abnormally high temperature within print head.
You have two choices to TRY to fix it:
1. put in new carts. press menu then start copy b/w then  fourtimes arrow up button (AUB) quickly one after another.
press by help of AUB and OK:
7 - (Ok) 6  - (ok) 4 (ok) then start b/w copy to initiate the carts and let the machine do some power cleaning.
leave the maintenance mode by pressing AUB 9 (ok)  and 9 again.
2. Make sure that the ph is at correct position simply by pressing on it from top (power up machine. wait til ph runs to left side. unplug from power. simpl press onto the ph). replug to power.
If you still receive the error the ph is defective due to bad generic ink and needs replacing.
Mar 21, 2008 | Brother DCP 130C All-In-One InkJet Printer
HP PSC 2355 all-in-one printer problem
try this:- go to device manager uninstal driver of your printer an restart your machine , now again instal driver of the printer by going to add printer manu.
if this does not solve your problem then try changing your toner/cartridge
Nov 25, 2007 | Computers & Internet
Paperjams
Sounds like the pick up rollers are worn or dirty.
You can try to clean them with alcohol.
When you pull the tray out the rollers
should be towards the front of the printer.
Nov 21, 2007 | HP Color Laserjet 3550 Printer
HP PSC 2355 All-In-One InkJet Printer Logo
306 people viewed this question
Seeker5211
Seeker5211
