My horizon Breezair remote control not working.I changed batteries now screen won't come on. How do i fix this?
  • 10865 Answers
SOURCE: Remote won't control the TV
Time warner will swap you for anew one. Call them and find out where to take yours for a swap.
Posted on Apr 11, 2009
issikiki
  • 563 Answers
SOURCE: My remote control stopped operating my Boston
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
Posted on Jan 26, 2010
dcramer531
  • 1654 Answers
SOURCE: the remote control does not work changed batteries
Either the sensor in the lower left of the set is blocked, dirty or it has failed. The remote for the set can also be checked at a place like radio shack or the dealer you purchased it from/ It is possible that that remote quit and the new on is not recognized by the tv. If you have another Sony tv you can try the remote on that and see if it turns off and on with the old remote, I believe most sony remotes at least work on the off and on function.
Posted on Feb 15, 2011
  • 11800 Answers
SOURCE: I have a mdl 26lc
I'm assuming that you are using the original remote, otherwise the programming on the universal remote might have been deleted and you will have to do it again.
You need first to find out if the remote is really dead: take the remote and a phone with a camera, go in a dark room, activate the camera, point the remote at the camera and press the buttons on the remote - if the screen doesn't light up whatever the button then the remote is dead. If the screen lights up then the sensor inside the tv is dead and it will have to be replaced.
Posted on Aug 03, 2011
spr1949
  • 1182 Answers
SOURCE: my remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Posted on Aug 03, 2012
Rca remote won't change different inputs
1) test the batteries for dead
2) clean the contacts batteries
3)tight the springs contacts batteries with long pliers for better contacts
4) open the remote control clean the KEYPADS for dirty, oxide, corrosion and fix itl
5) try it
6) if doesnot work,you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | RCA Universal Remote Control
My rca remote won't go to input or do anything
1) change the batteries by new ones
2) open the remote control clean the keypads from oxide, bad contacts,corrosion, dirty, and fix it.
3) try again, if doesnot work, you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | RCA Televison & Video
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Aug 02, 2012 | LG Televison & Video
WON'T CHANGE INPUTS
Reset your code according to the instructio manual.
2) change the batteries by new ones.
3) clean the contacts batteries with contacts cleaner
4) resolder the wires contacts batteries.
5) retight the springs contacts batteries with pliers if they have.
6) open the remote.control and clean the keypads switch, from oxide diryt, open contacts, or bad contacts with VOM.remember they must send signal infrared from SYScon Trans vs Sys receiver clean
7) Try.it
God bless you
Jul 30, 2012 | Logitech Harmony One Advanced Universal...
W-72 remote won't work
1) change by new batteries alkaline
2) clean the contacts batteries with isopropyl alcohol
3) tight the springs contacts for better contacts with pliers
4) open the remote control, and clean the keypads switch from dirty, oxide, corrosion.bad contacts, or open contacts. This will NOT trasmitt the infrared signal to the receiver.
5) Otherwise you must go to the repair shop TV for fix it
see the block diagram
Jul 26, 2012 | Casablanca Fan Versa Touch2 W-72 Remote...
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
My remote control for my TV won't work. I changed
See my response to your other identical question.
Mar 14, 2012 | Philips Televison & Video
Low battery icon on, won't recharge
Hi. If you do some research, you will find that this is a common issue with the Harmony One remote. I suggest using an elastic band to hold the remote firm onto the charger. That works for me.
Aug 03, 2011 | Logitech Harmony One Advanced Universal...
Heating & Cooling Logo
574 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
