Computers & Internet Logo
Posted on Aug 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fix it i reformatted my laptop but the resolution of my screen is so low. it's an acer laptop, i have a P4 Vga driver but everytime i install, the computer show that have up to 32 bit resolution, once i set it up on that resolution, the screen goes dark and never sow anything.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What is the make and model of the computer?
Atiq
Level 2:
Sergeant:
Champion:
  • Expert 257 Answers
  • Posted on Aug 01, 2008
Atiq
Expert
Level 2:
Sergeant:
Champion:
Answers
257
Questions
0
Helped
70707
Points
654
I need model no:? of your laptop....
My video card is to low after i format it
Adjust in Screen Resolution. Right click on desktop > Screen Resolution.
Or, You may have lost the driver. Check Device Manager. Right click My Computer > Device Manager > Display adapters. Update if needed. Download. Unzip. Run setup.
http://global-download.acer.com/GDFiles/Driver/VGA/VGA_Intel_8.15.10.2189_W7x86_A.zip?acerid=634444135912079955&Step1=NOTEBOOK&Step2=TRAVELMATE&Step3=TRAVELMATE%204740&OS=ALL&LC=en&BC=ACER&SC=PA_7
640x480 screen size please
Go to Control Panel - Display - Settings tab and move the pointer in Screen resolution to 1024 X 768
If you cannot increase the resolution the a generic VGA driver was installed and you need to install the correct video driver.
Download the video and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
1helpful
I have an acer extensa 4420. Recently I reformatted my laptop to Windows 7 Ultimate. Everything went smoothly, it works well, wireless and functionality is perfect. I have one issue, The screen resolution...
Hello Jonnyboy, looks like you are one of the Windows 7 driver problems, you may need to wait for the driver. the display should go to as much as 1280 x 800, try removing the VGA driver and use the standard windows driver.
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
When i type and or scroll my monitor flickers
its happen when the vga driver is not loaded or low memory
install the vga driver first to your computer
other wise upgrade the system memory
ok bye...............
1helpful
I reformatted my dell inspiron 6000 and upon installing the driver for the video the laptop went blank, but if i boot on vga mode windows comes thru
When you up the computer press F8 key then enter in enable vga mode.
Then go to control panel ->Display-> Settings
Then change screen resolution to 1024*768 then apply and ok.
Then check .
If still same issue then uninstall graphic driver and install again then it works.
Let me know if you need more assistance.
Thanks.
OS Vista
its an issue with the screen resolution....try changing the resolution setings by right clicking on desktop & go to personalize & then change the display settings.....set the resolution according to the width of your laptop.....for e.g if its a 15inch laptop, thn the screen resolution should be 1024x768....try changing the options for the best view....
1helpful
Acer Aspire 1403LC (app 6 years old) Screen resolution problem
You may have a corrupt driver, go to this site and down load vga driver, as i cannot see a grphics driver for your system http://support.acer-euro.com/drivers/notebook/as_1400.html
Grand Canyon Tech
Grand Canyon Tech
