Question about Refrigerators
I just bought an NEC FR 516R fridge/freezer and it didnt come with instructions on how to use the digital controls. Do u have any?
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
  • 10 Answers
SOURCE: Controls for the fridge on the side by side fridge freezer
If you have digital controls and if it works like a Kitchenaid you push and hold the increase temperature button.
Posted on Feb 16, 2009
SOURCE: Fridge and freezer stopped working.Power still on
The double dashes in your display are for one of two reasons. First situation would be would be "you turned the unit off". Press the up arrow on the feezer or fresh food control until a 4 is in each display. Second, if the control is locked out, the board has been scrambled or failed possibly from a power surge. Unplug unit for 30 seconds, and plug it back in and try to set control's for "4". If controls are still locked out, the board (12868513) needs to be replaced.
Posted on Jun 05, 2009
  • 1218 Answers
SOURCE: Only one temperature control??
Good day,
Yes, they are made. The temperature in the fresh compartment will be no issue, since you have control in that compartment.
The engineers designed the balance between the two compartments so the freezer would be normal if the following conditions applied.
1. The room temperature is between 70 and 90 degrees.
2. The machine has normal usage. I.E. 8 to 20 door openings of the fresh food door.
The freezer would start getting warmer if the room temperature dropped much below 70 degrees. or..
If the machine had extremely light usage with very few
door openings, or a combination of both situations described above.
With dual controls, and both set at normal, the above conditions would occur anyway, except you could over ride the normal settings to compensate.
Many people have this setup, and experience little trouble, but without knowing your life style replacing it would be your choice based on the facts given.
Thanks for using FixYa
Posted on Dec 23, 2009
Testimonial: "Very Good Reply, much appreciated"
  • 1702 Answers
SOURCE: NEC FR 405 Fridge/Freezer
Hi Sound like your freezer needs a new thermo switch. The switch regulates the temperture and turns it on and off. Replace and your good to go.
Posted on Jan 21, 2014
DAEWOO FR-661NW GETS HOT
Just a thought i would check if there. Is it possible an ice build up around the fan could be stopping it from turning?
Jan 24, 2014 | Danby 16.7 cu. ft. / 473 liter Upright...
Jan 21, 2014 | Refrigerators
NEC Fridge/Freezer FR405
I would go with high and check the inside circuklation fan see if its on..if not unplug the unit for 10 minutes and restart it..
Daewoo fr 094r 2.7 cubic foot freezer not cold
Its low on gas and needs re-gassing thats all ,bought it secondhand?? now you know why someone sold it
Jul 25, 2013 | Refrigerators
Good day,
Dec 23, 2009 | Refrigerators
Cant find defrost swicth on NEC fridge freezer
The defrost timer should be inside the refrigerator where the cold control is.
Apr 23, 2009 | Refrigerators
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Feb 16, 2009 | Whirlpool GS6NBEXRS Side by Side...
Refrigerators Logo
150 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
