Question about Cobra 148 GTL 120-Channels Base CB Radio
I have a Cobra 148 mounted on the hump in a pickup truck and it works fine. Then I plugged in a old Turner +3 desk microphone and I get bad feedback when it is keyed up and I can also hear my voice thru the speaker in the radio. If I move the microphone away from the radio and turn the volume down on the mic it isn't as bad.
    Problem Solver:
  • 4 Answers
You're most likely getting lots of RF feedback from the metal cab of your truck,combined with the real sensitive nature of the amplified Turner mike.I would put an old original Cobra (coffin mike) handheld mike or a Astatic Roadking 56 (RK56) on it.They are really hard to beat,especially when you have lots of feedback & squealing. I also have a 148GTL (malaysia made) that has a Turner +3 deskmike & it squeals in my truck but not in the house. The 148GTL has given me better service than ANY other radio I've owned.It has 120 channels (freeband) & upper & lower sideband. I think mine is a 5pin Cobra-type plug-in. Try a simpler mike & good luck. Squirrly
Posted on Mar 17, 2011
Why does the uniden granr xl go into the transmit mode when turned on
Wrong Microphone, Shorted leads in the microphone plug or a bad transmit switching transistor.
Aug 17, 2014 | Uniden 2SC1973 Transistor for Grant and...
Tip
Enhance your audio transmit
i advice to use a Desk Microphone whenever at your Home or Office, it enhance and make your audio clearer and most of all louder, even if your Signal is weak , having a Loud and Clear audio will perform better than a strong signal with a Stock Audio. Monitoring stations will hear and be amazed with a small signal but a loud audio.
suggested mics like Turner plus two, Turner sidekick, and the famous Astatic Microphones
it can be also connected to Echo Chamber to provide nice effects.
most of all, the antenna, ..no matter what radio, the one with a good antenna performs better, than a setup with booster having poor antenna installation. typical SWR is 1,1 to 1.3, if you can get 1.5 its good but 1.0 is best. Good grounding is also important.
for Omni , i suggest a Golden Penetrator antenna , it is a 5/8 wavelenght Vertical Antenna ,
a 2 element Quad or a 3 element Yagi Antenna for directional one.
and a good Regulated Power Supply too, must have at least 6A minimum,
higher is better.
on May 29, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Looking for the best micaphone for cobra 148gtl
Turner+2 Ham CB Radio Microphone Transistorized SSB Base Station Shark Fin
turner microphone ' eBay
Jul 29, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
Mar 14, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I have an old cobra hooked up worked fine the the
Sounds like you could have a bad soilder joint in the radio. If you hit the top or bottom of the radio does it help? If so its soilder. You match your antenna to your truck not the radio. You might want to recheck it.
Jul 18, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Explaihow to wire a turner +3 mic to a president washington base
Here you go 1/shield 2/white 3/black 4/red . Good luck......Dan
Apr 28, 2009 | Magnum DeltaForce CB Radio
5 pin mic
All "older", "real" or "desirable" Cobra 148 GTLs came with side-mounted 5 pin microphone sockets. For wiring information, see...
http://www.offroaders.com/info/tech-corner/reading/mic-wiring.htm
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
103 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
