Question about RCA Audio Players & Recorders
I have a RCA clock model RP5435C that will not switch over to daylight savings time...what should I do. I have already tried unplugging it, but that didn't work.
  • 604 Answers
If the clock radio is coming back on without being plugged in or still has the time on it when plugging it back in, it probably has a backup battery, take the battery out. Why can't you just reset the time to the correct time, just push the time set button, then the hour button, etc.
Posted on Mar 14, 2011
Hi! I have a problem about my radio clock, the time clock is blinking..how to fix my radio alarm clock the model is rca rp5435c? I need some HELP!
You have tried re-setting it, Right?
What happened when you did?
Note: This problem ended up under Vacuum cleaners-
You might want to try re-listing it again-- under Electronics?-
Mack B
Jan 26, 2011 | Vacuums
Hi i have a rca Clock Radio RP5435C i need to know how to set it.
Move the switch on the top back to either the clock symbol to set time or alarm 1 or 2 depending on which one you wish to set. On either side of the snooze button is a fwd and rev button. Push fwd to advance the time or rev to go back. If setting the alarm it will automatically turn the alarm on when you set it. To turn alarm on or off manually, push the button for the alarm you choose on the top rear right side.
Jul 19, 2010 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
CAN'T SET TIME. TRIED TO CHANGE IT TO DAYLIGHT SAVINGS TIME MA AND IT DID NOT FUNCTION.WHEN I PLUGED IT ON, IT WENT OT 12:00 AM. DID NOT PICK UP THE TIME. I CHANGED THE BATTRIES AFTER CHECHING THE NEW...
On top of the radio is a slide bar for alarms. Slide to the far right, you will see a clock icon. Plug the phone in with it in the far right position.
Make sure your time zone is indicated. There is a switch DST, which stands for daylight savings time, which needs to be in the correct position - on or off.
Apr 05, 2009 | RCA RP5420 Clock Radio
RCA atomic clock radio didn't reset to DST
Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
Mar 09, 2009 | RCA RP5430 Clock Radio
Can't change clock to eastern standard time
Can't solve it but the clock doesn't know the government changed when daylight ends.
Nov 04, 2008 | RCA RP5430 Clock Radio
Setting to/from daylight savings time?
Press the white button on the base of the clock,
Harry
Jun 19, 2008 | RCA RP-3765 Clock Radio
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Can't set the time
You can disable the daylight saving time function using the DST switch. Setting the time requires you to slide the 4-position slide switch on the top rear to the right to set the time.
Nov 06, 2007 | RCA RP5420 Clock Radio
Help daylight savings time is not here yet
I am going to try changing to time zone 7 (Hawaiian Time). Hawaii does not observe DST so this should turn the clock into a regular clock that ignores DST and you need to set yourself twice a year.
Oct 30, 2007 | Emerson SmartSet CKS1850 Clock Radio
Daylight saving time issues
I picked this up from the Emerson Website Read below before going to the link. Try thi link: and poke around the website http://www.fox-international.com/emerson/ Important Notice About Daylight Saving Time (DST) and Emerson SmartSet® Clocks and Clock Radios Congress recently passed a new Energy Bill which includes a provision to extend Daylight Savings Time. At the beginning of 2007, Daylight Savings time will begin on the second Sunday in March and end on the first Sunday in November. Because of this change your SmartSet® Clock or Clock Radio will need to be updated. In order to set your unit we will need the following information from you: 1. Model Number You can find your model number on the back or bottom of your unit. (Click here for an example) 2. Serial Number You can find your serial number on the back or bottom of your unit. (Click here for an example) Based on this information we can identify which setting is necessary to adjust your unit for compliance with day light savings. There are three possible groups your SmartSet® Clock or Clock Radio could fall into: Group One changes the time zone to a previous time zone. Group Two adjusts for the spring and fall settings. Group Three is already set for 2007 daylight savings compliance. Group identification begins with your serial number. The first three to four digits of the serial number represent the year and month of manufacture. (If your serial number begins with 0607, that would indicate July 2006, 506 would indicate June 2005.) Models manufactured before January 2006 (serial number 506, 512, etc.) will follow Group One settings. Models manufactured between January 2006 and July 2006 (serial number 0601, 0603, etc.) will follow Group Two settings. Models manufactured after July 2006 (serial numbers beginning with 0608) are Group Three and do not require any changes. If you believe you have a Group One model, please click here. If you believe you have a Group Two model, please click here. If you cannot determine which Group your model may be in, please call us at 1-800-526-7521.
Mar 11, 2007 | Emerson SmartSet CKS1850 Clock Radio
211 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
