I bought a used aerow pro 971 by Ross rowing machine There is no power to the control panel. Is it battery powered .and how do I get inside the box? Luwayne Stout
2 Suggested Answers
  • 3 Answers
SOURCE: My Goldline Aqua Pro control panel says "no cell p...
See on www.manulabo.com/hayward to have your solution
Posted on Jul 06, 2010
How do you find battery charge level?
You can click on Start ' Control Panel ' Power Options. The Power Meter tab will give you battery status (charge level) , and the Advanced tab will allow you to select a check box to put a battery status icon in the systray (lower right corner of the screen). Remember to click the Apply button to make changes permanent.
Jul 05, 2014 | Dell Latitude D610 Laptop Computer -...
I can not boot I get power saving mode message on my monitor how do I boot
Click on "Start" in the lower left-hand corner of the desktop. From within this menu, select "Control Panel." Double-click on "Power Options" located inside the Control Panel. Turn off the power saver plan by selecting one of the other power plans listed inside the Power Options dialog box. If there are no other power plans available, you can create one. Create an alternate power plan by clicking on the "Create a power plan" link on the left-hand side of the Power Options dialog box. This will open another window allowing you to create a power plan of your own. Select the type of power plan that you want, and enter a customized name for this plan. Once you have done this, click "Next." You will then be able to edit the plan's advanced settings to include how it handles the display, sleep mode and brightness settings under the battery and when it is plugged in. Hope this helps.
Dec 17, 2012 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Fuse location for power windows 2003 Buick Century
There really isn't a fuse for just the power windows and if a fuse was blown that did control the power windows pretty much everything that the body control module works would not work so i believe what you would be looking for is the circuit breaker for the power windows. That circuit breaker is located in the instrument panel fuse block . You need to open the passenger door to see the fuse panel cover. Anyhow I don't have a picture but the circuit breaker is on the top row second one over from the left. I hope this helps and good luck.
May 17, 2011 | Buick Century Cars & Trucks
When I unplug the power cord the monitor is bright. How can I keep it bright with the power cord in?
Normally the screen will dim when you UNPLUG the power cord. Is that what you are experiencing?
That is quite normal and is a feature designed to lengthen battery life when the machine is not connected to mains power.
In any case you can adjust the screen brightness. To do this you should be able to use the function keys together with the Fn button. You should find two function keys (along the top of the keyboard) that have symbos like a sun and a Plus sign and a Minus sign on them. Press the Fn key (bottom left on the keyboard probably) and then tap the 'sun +' key to brighten the screen.
Hope this helps. If not, please respond with a comment and I will give further details.
Feb 07, 2011 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
I have aopen ax4bs motherborad and i don't know where the power sw goes
If you look at the picture below, I have circled in red the two parts you have to connect for your power supply to the motherboard.
Nov 24, 2010 | AOpen AX4BS Pro (91.89J10.001) Motherboard
Where can i place in my motherboard power & reset jumper, i need diagram of my motherboard
For any desktop computer using Windows:
The main power cable coming from the Power Supply, is an ATX main power cable.
It is the power cable with the longest connector.
It will either be a 20-pin, or a 24-pin connector.
IF, this is directly towards an eMachine T2893 Desktop PC, it uses an Intel D845GVSR motherboard.
Also note that eMachines Support > Specifications, states the T2893 uses an Intel 845GV motherboard chipset,
( Chipset ),
http://support.gateway.com/emachines/PC/eMac/4176/4176sp5.shtml
Info on the Intel 845GV chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
This is the download link for the motherboard manual, for the Intel D845GVSR motherboard,
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
Scroll down, and click on the blue -
Intel Desktop Board D845GVSR Product Guide (PDF)
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click it may take up to 30 seconds before the first page comes up.
{ 10 seconds, fully loaded. Adobe Reader 10 (X), and medium speed DSL connection }
The plastic front of your desktop computer is the Front Panel.
The rectangular area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header. (Sometimes abbreviated FP1 on the motherboard )
Looking at your motherboard as it's installed in the computer case, the Processor is to the Top, Ram Memory to the Right, and the long white PCI slots to the Bottom.
The Front Panel header is on the Bottom of the motherboard, under the CMOS round battery.
There are two rows of pins.
4 across the top, and 5 across the bottom.
{ Top row 4 pins, space
Bottom row 5 pins }
The Top row of pins are numbered Even.
The Bottom row of pins are numbered Odd.
Starting from the Left side of the header going to the right, on the Top row;
{ Left side of the motherboard going towards the right side of the motherboard }
Pins 2, 4, 6, and 8. There is No pin 10.
Starting from the Left side of the header going to the right, on the Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the harddrive LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch. IF a reset switch is used.
C) Pin 9 is for 5 Volt (DC) power. Not used.
D) Pins 2 and 4 are for the Power On LED light.
E) Pins 6 and 8 are for the Power On switch.
To the right, and up, is the BIOS Configuration Jumper Block.
3 pins.
Pin 1 is towards the CMOS battery.
Normal default is the jumper is on Pins 1 and 2.
To configure it is placed on Pins 2 and 3, BUT in a proper method.
Read on Page 37.
(37 in page number box at top of PDF file )
For additional questions post in a Comment.
Regards,
joecoolvette
Nov 24, 2010 | E-Machines T2893 PC Desktop
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
Washing machine won't turn on
For the F&P machine.
Check the circuit board fuse. I had my machine do exactly the same thing. Just wouldn't power up at all, no lights, nothing.
The fuse is on the circuit board a small round red unit, with T1.6A250V written on the top.
Remove the 2 screws securing the control panel. Inside there is a grey plastic box. This houses your circuit board. You will need to have a multi meter and a soldering iron to replace this component.
May 22, 2006 | Fisher and Paykel (IWL12)
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
