Question about Garden
Lights blinking when charging battery on ridgid charger
SOURCE: Battery charger(BC-11L)
Battery charger will not hold its charge. the red light keeps blinking
Posted on Oct 09, 2008
SOURCE: charger
I am posting an answer to my own question... I called Casio Customer Service and gave them the model # and problem. They instantly sent me out a brand new battery. Turns out they have had a lot of problems with these batteries and will replace them absolutely free of charge.
Posted on Oct 24, 2008
  • 4 Answers
SOURCE: when battery is placed in charger, red light
You can jump start the battery by taking a piece of speaker wire2.gif (any wire) and contacting it to a 9-volt battery for 30-60 seconds. Make sure to contact the positive to positive and negative to negative, or you may short the battery. After jump starting it the battery should charge as normal.
Posted on Nov 02, 2009
SOURCE: On my camera the battery
Before you get creative and directly plug your batter into an AC adapter, try something much easier first. I have the same problem with my Olympus 770SW batteries. As silly as it sounds, the charger will only work in a select few outlets in my house that I found by trial an error, actually pure frustration. I suggest, go around your house and plug the blinking charger in all the outlets and see if you find one that works. That sounds a lot less shocking than solution 1 and 2 now doesn't it? Good luck!
Posted on Mar 19, 2010
  • 760 Answers
SOURCE: I purchased a new DeWalt
If you look on the charger there should be a flashing codes should be explained depending on the type of flashes. Very fast flashes, means bad battery.
Posted on Oct 02, 2010
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 | Toys
Charger will not charge radio, has red blinking light
If the radio will charge on one charger and not the other, the one with the blinking light is bad or has a dirty or defective battery contact. Check your charger for debris and clean your battery contacts with a pencil eraser and try charging again. If this fails, replace your charger.
Best regards.
Jan 31, 2014 | Kenwood KSC-37 Replacement Charger for...
My ridgid 24 volt battery wont charge or the battery charger doesn't work how do i test it
there are points where the battery connects to the charger. these points can be tested with a DVOM (digital volt ohm meter- and it can just be a volt ohm meter, it doesn't have to be digital ) - your meter should read voltage when checking across the points. Now if it has a button to turn it on and you turn it on and measure nothing, you're going to have to open the charger up... there is a lot more to this testing... next time, include model number for the charger please
Oct 25, 2013 | Ridgid Drills
NIKON MH26 BATTERY CHARGER BLINKING GREEN LIGHTS
A blinking green light means the charger is charging the battery. A steady green light (same LED) means that charging is complete. If the light never stops blinking and we assume that your charger is working correctly, you may have a defective battery. Rechargeable batteries do not last forever. After a few years, there ability to take and hold a charge declines. It may be time to buy a new battery.
Apr 10, 2013 | Nikon D Cameras
I have a power problem with a RIDGID 18v rechargeable drill. The battery charge indicate charge and the unit won't start . One of the batteries was left in the charger for several weeks. I use this...
I leave my 18 volt batteries charging year round even if I do not use my drill I switch batteries about once a month to keep them both up to snuff. your new chargers are made to do that unless the instructions tell you not to. I was told even new batteries will not hold their charge if allowed to completely run down and stay there.
Jan 31, 2018 | Ridgid Garden
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
Batteries wont charge at all both lights blink signifying "malfunction"... wtf???
Batteries need reconditioning, but likely they need to be replaced if not new. If new, the charger may not be working.
Feb 07, 2010 | Ridgid ZRR82007 Factory-Reconditioned 12V...
R86006 Li Ion 18v Cordless drill - When trigger is pressed, drill runs for a moment and stops. While charging battery, both the green and red lights blink permanently. Is battery and/or drill bad?
Sounds like it is more between the charger and battery. Sounds like a newer model, Can you test it with an alternate battery? Chk the battery voltage and the charger output against the data plates.
Oct 20, 2009 | Ridgid Power Tools Pressing Tools...
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Garden Logo
390 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
