Question about Cycling
Need to find rear derailleur and hanger and parts for k2 Cheyenne in Minneapolis
    Brigadier General:
  • 8,546 Answers
How do I reattatch the right rear brake on my k2 cheyenne bike? It just fell off!
from the frame or the pads? if it fell from the frame then you might need a new nut or maybe see a bicycle repair shop.
Sep 06, 2012 | K2 Cycling
Rear Derailleur mount broke. I need the bike for Ironman Wisconsin on Sunday, so my LBS cut the remainder of the mount off and mounted a new hanger that threads onto the QR skewer....meaning that, to...
The only other solution I can think of is to shorten the chain and make it a three speed by eliminating the rear derailleur all together. If you have found a way of remounting your derailleur though I would go that way. All the best in the Ironman
Sep 10, 2011 | Cervelo P2 Carbon
Mongoose Maxim 26" mens bike-
If it's "broken" or even bent it will have to be replaced. Your frame or derailleiur hanger may also have taken a fatal hit.
You should consult a Bike Shop.
If you still want to DIY you'll need to obtain some specialized tools and skills.
http://www.parktool.com/blog/repair-help/rear-derailleur-hanger-alignment
http://www.parktool.com/blog/repair-help/chain-installation-derailleur-bikes
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Jul 09, 2011 | Cycling
Mongoose 21speed spear derailer is bent. bought at yard sale 60.00 dont want to put much money into. what is the best way to fix this. how much? Want to use as spare bike. it is rideable but how long....
A new Rear Derailleur may cost more than you paid for the bike. But is IT bent or is it the derailleur hanger?
Search the web for "fix bent derailleur"
Steel frames can be re-formed but not most other materials.
Someone in your club should know how to deal with it and maybe even have an old derailleur hanging around.
Jun 30, 2011 | Cycling
Derailleur hanger for connondale flash carbon 4 2010 i think the part number is kp 121
What's the question?
Use a Search Engine for it and you will find many for sale. Also check eBay.
Go here and find all the documents on hangers...
http://www.cannondale.com/manuals
Jun 15, 2011 | Cannondale Derailleur Hanger For Rear...
I need a derailleur hanger for a Schwinn S-25 dual suspension mountain bike. I don't have the hanger. Is there a part or model number for the hanger so that I can order a new one?
Most bike shops can match up the broken pieces. If that doesn't help check this link to see if you see one that looks like yours.
http://www.jbimporters.com/web/advanced_category_result.php?CatOneId=DERAILLEURS&CatTwoId=REAR+SMALL+PARTS&CatThreeId=WHEELS+MANUFACTURING&dfadfkawe45d9drh=3
In case you are not aware Schwinn folded in 1999, The name is now being used by Pacific Cycles. If all else fails you might be able to order one from them. Good luck.
Dec 20, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My sram x-7 derailleur hanger broke and i bent the derailleur. I've replaced the hanger and re alligned the derailleur but i went to bolt the derailleur back onto the hanger but the bolt doesnt seem to be...
You need to replace the main pivot bolt, something (most likely a tab) is broken. This one is best taken to your local bike shop for inspection. There may be something your missing like a crack in the body or another broken part. Link to Manual.
You can also contact the SRAM customer service for support, but they will refer you to a shop to take care of the problem and order any parts on this type of problem.
Dec 14, 2010 | Sram X7 Mountain Bike Rear Derailleur
Chain coming off fron gear when coasting or trying to pedal backwards? Local bike repair shop indicated that a bearing maybe shot but that they couldn't replace the front gear unit.
Oh, it is too bad you are in the Bronx. i'd have that fixed right quick. There are probably a pair of culprits at work here. One, your derailleurs no doubt need adjustment. Two, your rear derailleur hanger may be bent. These two can both cause the problem. Start with the rear hanger, because that will be easier to see.
Flip the bike onto the bars and saddle and take a look at your rear derailleur. Is it going straight up and down and is it aiming straight with your frame? If it isn't, you have found your problem. The hanger needs to be straightened. This can be done without any tools if you have a good eye. Hold the derailleur by the body and bend it to make the alignment good with the cassette. If this is NOT the problem (but i really think it is) then here is a walk-through on adjusting your derailleurs and hopefully this will solve it.
Here is how to adjust the rear (first):
-Set your front gear to its middle position.
-Shift the rear into the highest gear.
-Disconnect the derailleur cable.
-Screw the barrel adjuster on the shifter (or down tube if it is a road bike) to fully turned in clockwise.
Screw the barrel adjuster on the rear derailleur to its halfway point.
-On the back of the rear derailleur you will see two screws. One will be marked "H" and the other "L". These mean high and low. Adjust high to get your jockey wheel on your derailleur perfectly centered over the smallest cog on the cassette. Manually shift by pushing the derailleur (while cranking the pedals) to the largest cog (1st gear) and set this stop on the derailleur "L" where the jockey wheel is over the cog, but past it where it would be touching the outside of the cog if they were side-by-side.
-Pull the derailleur cable taut and re-tighten it.
Shift the rear to the middle gear and adjust the derailleur using the barrel adjuster to center the jockey wheel directly over the cog it should be.
-Now shift up and down the cassette, cranking as you go and in every gear, back-pedal to make sure there is no problem with the gears hopping. If they do, adjust as necessary with the barrel adjuster.
Here are some tips for the front:
-Shift into low gear on the front and rear derailleurs. Make sure the chain is not rubbing on the front derailleur. If it is, adjust the screw marked "L" until the chain just clears the derailleur but does not touch it.
-Now shift the front into the middle gear and while it is still in the low gear in the back, crank to make sure the chain is not rubbing on the front derailleur. If it does, adjust the tension of the cable with its barrel adjuster.
-Shift the front into high gear and shift the rear to the highest gear, cranking as you shift. If the chain is not rubbing, you are all set.
Sep 16, 2009 | Cycling
The chain is rubbing on the rear tyre when its free wheeling. what do I do?
You may have too large a tire on the back for the bike. However, if the derailleur hanger is bent, this could also cause the problem. Flip your bike over onto the bars and seat and make sure the derailleur alignment is good (vertically and longitudinally straight). If the derailleur hanger is straight, then you will have to use a narrower tire in the back.
Jun 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
Cycling Logo
56 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
