Question about Whirlpool Washing Machines
Spin cycle sounds like a jet plane, machine rocks and rolls. have had washer for one week.
Washer was under warrenty. called whirlpool and a service man camed to the house.i did have a wonerful response from your site and will call the appliance service man, when washer is no longer under warrenty,who called me yesterday and gave me lots of information. thank you!
Posted on Aug 02, 2008
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Jet Plane noise in spin cycle
The bearing in the outer tub assembly is going out and you will need to replace it. Here is the part if you want to order it but you might want to look into buying another machine.
Nov 20, 2012 | Washing Machines
Sounds like the inside is a jet plane while in spin cycle very lose inside like something is loose ore broken like a belt
If the washer is vibrating a lot, then you could have a bad drum bearing. There are also counter weights and shock absorbers that could be bad. The best thing to do is take off the back panel and look inside. many times the problem can be clearly seen. Usually a loud noise like a jet plane on spin cycle means a bad bearing. This can be costly unless you can do the work yourself. The parts are readily available.
May 26, 2010 | LG WM-1832C Front Load Washer
Washer sounds like it has rocks in it during spin cycle.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 13, 2010 | Whirlpool GHW9100L Front Load Washer
Noisy during spin cycle, sounds like a jet plane at full spin.
the drum bearings have gone, expensive repair, this is caused by over loading the machine
Feb 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
100 people viewed this question
Dan Webster
Dan Webster
Sal De
