Black screen have tried changing outputs but still black screen.
    Problem Solver:
  • 10 Answers
Check for loose video connectors, power cables (of your monitor). Also try to turn off your computer by pressing and holding the power button. (you know your computer is off if it doesn't make any sound or vibration)
if all else fails, power up your computer and listen for a tone/beep sound. If there is a long beep sound probably your memory (RAM) is loose, defective or faulty. If you hear a tone/beep in a patern (like long-short-long, or any other pattern) then probably your VIDEO CARD is loose, defective or faulty.
Posted on Aug 01, 2008
My sons ps3 screen is black after trying to hook an old off brand web cam is there a fix for this?
You will have to disconnect the web cam first. Then follow some simple steps to reset the video output on the PS3. I will post a link to a youtube video that will guide you thru the steps.
HOW TO RESET HDMI Video PS3
May 03, 2014 | Sony PlayStation Video Game Consoles &...
Tv screen turns black and red when playing through pioneer receiver
Usually when I hear of solid colors that display on a TV, my first solution would be to change the cable. We know your DVD player is working as you connected it straight to your TV and you report no problems. I assume you are using a composite cable (red, white, and yellow) Red and White being the Audio and Yellow your video.
But since your player works...and your tv works under the same input, then the only other issue would be the output cable from the receiver or the actual composite input or output connector is faulty.
try a video game system in place of the dvd player through your receiver..if it happens again, then change the receiver's output cable...if it still persists then your reciever's output connector is faulty.
I hope this helps.
Aug 09, 2012 | Audio Players & Recorders
When I tried to play a DVD movie, because the picture on tv is B&W I tried to change the video output mode to something like 'entrelaced'. Then the tv screen turns to black and display the...
On the DVD player most of the time you have two outputs. One in cinch and one in scart output.
If one doesnot work try the other output to be able to reset what you have done. Or try to disconnect from the power for a few minutes it might work as well.
May 31, 2011 | Electronics - Others
My xbox 360 is playing in black and white
Which TV Output do you have, mabye when you changed that PAL setting you screwed it up, and it made it black and white. If its an HD Screen make sure your switches and all of your plugs are plugged in.
Apr 07, 2010 | Microsoft Xbox 360 Console
I would like to hook a flat screen tv up to a Dell latitude D505 laptop with an Intel 855 GME graphics controller. The TV screen is black. I have the latest driver. What can I try?
Most laptops have a video-option:
* output only to the internal screen
* output only to the external screen
* output to both screens
Set your screen-resolution to 800-by-600, which your TV should support, and then "toggle" the option to choose "output to both screens'.
Jan 02, 2010 | Dell Latitude D505 Notebook
My tv get snow when i try to play a game
Try using another TV. If you don't get the same problem then it's the TV and not the PS3. You might also want to try changing the display settings so that you're using the correct outputs.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
Screen randomly flashes black
First and foremost you need to change one of two things. Either your video output settings on your xbox 360, or use an hdmi cable as opposed to component cables. Component cables are only designed to output video up to 1080i, not 1080p(big difference). So if you try to run a output signal of 1080p with cables only made to send 1080i, you will have picture issues.
Nov 23, 2008 | Sharp Aquos LC-32D40U Television
I have a Polaroid DRA-01601A DVD Recorder (w/160gb hd). I am getting a video output on my tv as a black and white split screen. Can you help?
The picture output may be set for other than 480i. Try to connect the composite output, and you may get enough picture to change the setup to 480i.
Oct 13, 2008 | Polaroid Televison & Video
Black screen
you mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Sep 14, 2008 | Orion1934 19" TV
Black screen but will power up
try outputing to an external monitor.. thats the best way to see if you lcd is burnt out if it does output.. but if it doesn't it mite be you graphic card or driver.. but try that and see wat happens..
Good luck
Jan 06, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
David Payne
David Payne
