Question about Casio G-Shock GW500A-1V Wrist Watch
How do you set the time to dst. - Casio G-Shock GW500A-1V Wrist Watch
  • 12 Answers
From the main time display, hold down the adjust button until it beeps and your time zone is flashing on the bottom of the display. Then press the mode button once. [AUTO/ON/OFF] DST will be flashing on the bottom. Use the Time Memo and/or Receive buttons to cycle the mode. When it's what you want, press adjust twice.
Posted on Mar 13, 2011
Watch not showing correct time ,my location is set orrect
If your watch is 1 hour out it could be showing daylight saving time (DST).
If this is the case, then press the mode button until you reach DST and then use the one at 2 or 4 O'clock to turn it off or on as required.
Jun 11, 2011 | Casio Wave Ceptor Watch WVA104HDA
My casio wave ceptor 3054 wv-58a is not working right. I live in Phoenix,Arizona and we don't observe daylight savings time and when I went to take it out of dst mode the day of the week is in a foreign...
The correct time zone setting for Arizona on this watch is YEA (Edmonton International Airport). Hold the adjust button for several seconds until the three code time zone starts flashing, then use the forward/back buttons to select YEA.You need to keep the DST mode off, so press mode once, then the forward button to select off in the DST select screen. From there, you can then press mode to manually adjust each time/date area individually. The final thing that you can adjust is the language, choose ENG for english. Press adjust to keep your settings, and you should be good to go.
Mar 14, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
I am unable to set the time because the function button (top left over the 10 O'clock position. I had a local watchmaker tell me the button moves, but it has no effect on the electronics. Casio has an...
I have a different model of Casio but I suspect that the operation is the same.
To change DST you should press the button (8 O'clock) to give world time. This should be showing your city.
You should then use the button you mention to toggle between DST & ST. (ST is no DST display!).
If this does not work and you wish to read through instructions for your particular model, then go to casio.com, select "support", and under "technical support" select "manuals", then "watches", agree terms, and the select "watch manuals archive", insert the required number off the back of your watch and download the instructions.
Jan 28, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
DST on MTG900
The MTG-900 supports automatic DST which can be activated in the time setting mode.  However, the ROM in the MTG-900 dates from before Congress (in their infinite ability to make mistakes) modified the DST schedule, so, instead of switching at the beginning of April and the end of October (as currently specified), it switches at the end of April and the beginning of October (as previously specified).
I do not believe that there is a way to change the DST scheduling or manually turn DST on or off.  I've resorted to changing the time zone manually and turning off the DST feature.  IOW, I set the timezone to Pacific (LAX) during PST, and, to Mountain (DEN) during PDT.
Mar 10, 2009 | Casio Atomic-Solar MTG900 Watch
Echo drive skyhawk,My watch's time zone is always one hour behind
You posted this in January, which is not during daylight savings time. The SMT setting doesn't turn on automatic DST switching for a particular timezone; rather, it is a manual override to adjust timezones to DST when it is actually active. There is no automatic DST adjustment for this watch (according to their FAQ). Turn SMT to OF for all timezones during winter months, and ON for applicable timezones during SuMmer Time (SMT).
Jan 17, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How do I get the wave ceptor to come on ?Casio-2688
Try Googling (casio)(2688)(manual) without parens for instructions.
May 08, 2017 | Casio Watches
Time zone
You don't need to set the watch back an hour.  You just need to turn off the automatic DST adjustment.
Hold ADJUST for several seconds.  Then, when DEN starts flashing (or whatever timezone you are set to), hit MODE The display will change to DST flashing at the top and on or auto flashing at the bottom. Click TIME/MEMO or RECEIVE to change on->auto->off.  Once off is flashing at the bottom, hit ADJUST twice and you will be out of DST mode and everything should be fine.
Nov 08, 2008 | Casio Atomic-Solar MTG900 Watch
How do you set the time on a casio g shock watch????????
I had the same problem following recent daylight savings time (DST) change. The watch has three DST mode settings (ON, OFF, and AUTO). You get to the setting mode by pressing and holding the "adjust' button until the city time zone indicator starts to flash. Then press the "mode" button. This should give you the DST setting. Now press the "receive" button to cycle through the ON, OFF, and AUTO modes for DST. I set it for AUTO. I then existed the setting mode by pressing "adjust" again.
Now you can initiate a manual update of the time by pressing and holding the receive button. Put your watch by a window and make sure the signal strength indication is showing level 4 (full picture of satellite dish on my version). Give it a few minutes to down load new time.
After doing this the watch corrected itself and now shows correct time. Other wise I assume you could set the DST function to ON or OFF as well depending on whether you need to add or subtract the hour from the time.
Oct 26, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Atomic watch
You most likely don't have the Daylight Savings Time (DST) set to AUTO mode. Just hold the ADJUST button until the time starts blinking. Then hit MODE and DST will show on the top. Hit RECEIVE as needed until you see AUTO in the bottom. Then just hit ADJUST 2 more times and you're set.
These instructions are actually for my Casio G-Shock MTG-900 but I imagine they're very similar for most G-Shock atomic watches.
Nov 15, 2007 | Casio G-Shock G701D-2AV Wrist Watch
Casio G-Shock GW500A-1V Wrist Watch Logo
232 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
