Question about Car Audio & Video
When I turn the radio on the only thing that shows up it is ErrE. Pushing any of the buttons on the radio does not change anything.
  • Car Audio & ... Master
  • 4,932 Answers
This is usually because wrong codes have been entered
Leave it SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
This may take an hour or more
Posted on Mar 13, 2011
Electric, dome lights, dash display, radio
Yes, probably it's a fuse.
Try to remove the fuses one by one and check if there is a broken one and replace it.
Aug 26, 2008 | 1994 Jeep Grand Cherokee
Radio,tape player,cd won't come on.
The radio may just not work. I had one like that at one time. It looked as if it was working but wouldn't turn on or do anything aside from light up. If you can't get it to work I suggest just finding a new one.
Apr 14, 2012 | Honda CRV Cars & Trucks
Error code: errE on radio
either the radio must be replaced, because honda has problems with the radio. or you need to disconnect the battery for 10 seconds then put in the radio code again
Sep 06, 2009 | 2004 Honda Odyssey
Radio not working
check the wireing on you stereo sometimes they wire the yellow-illumination to red-positive which makes your batterie die everytime
Mar 14, 2009 | 2003 Honda CR-V
I had to jump my car and now my radio and clock wont work.
Get a boyfriend stop jumping the car...JUST KIDDING. You must have a reset button, it's not very big , you can push the reset with a pin, it's a small cercle on the right hand side of your radio. Try that and let me know
Dec 23, 2008 | 2004 Honda Accord
Radio does not work.
what you need is the radio code to get rid of the error code just disconnect both battery cables touch them together for approx. 30 seconds reconnect cables turn on the radio it should read code there might be a credit card size card in the glove box with the radio code if not look for a sticker in the glove box this is your radio code if not then the radio has to be removed to get the radio seial# then call a honda dealer up give them this number and they can look it up or if your bought the car new call that dealer up they should have this in their history
Nov 14, 2008 | 2003 Honda Accord
Radio code
If you don't have the radios security code, you can try entering 1111 as some replacement radios were coded with this security code. Your local Audi Dealer may be able to provide the correct security code for your vehicle, if you provide them with your vehicles Identification Number (VIN). This VIN is typically located on the drivers door pillar.
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
To enter the code on the Wiesbaden Radio: Turn on the radio, SAFE should be displayed.
Push and hold the AM/FM button, then while holding the AM button down, push and hold down the SCAN button. Release the AM/FM and SCAN buttons, and the display should show 1000. Now enter the correct code using the radio pre-set station buttons (1-4). Button 1 changes the first digit in the code "1"000, Button 2 changes the second digit in the code 1"0"00, button 3 changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the AM/FM button, then while holding down the AM/FM button, push and hold down the SCAN button. The display will then show SAFE, release the two buttons, and now the radio should play correctly.
Sep 19, 2008 | 2001 Audi S4
My daughter borrowed my car (a 2003 Honda CRV EX) and accidently left a light. After jumping the car, I found the radio/CD player does not work. The time is correct and is blinking. If I hit any button,...
You'll have to get to the dealer to have them give you the Radio lock out code. Once they give you the code, punch it in, and everything will be back to normal.
Jul 22, 2008 | 1999 Honda CR-V
Pair of radios won't talk to each other
Have you checked the QT filter? The T5950 have an addtional interference filter called the QT filter. It filters out other radios and allows Motorola radios to speak only to other Motorola radios with the filter. Check the QT setting on both radios by pushing the menu button 6 times, the QT setting will show. If it shows a straight line on the display the filter is not on. Now push the + button (beside the menu button), to turn the QT filter on (a Y will show on the screen when on) or the - button to turn it off (the line will show when filter is off). The radios have to match all channels and all filters to talk to each other.
Dec 09, 2007 | Motorola Talkabout T5950 (7 Channels)...
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
