Question about Cooper Wiring Devices 274V-BOX DECORATOR SP SWITCH & GROUNDED RECEPTACLE
I have a 274V outlet w/ switch for my garbage disposal. I hooked it up and used a MICRONTA 3-prong circuit tester on the power outlet to make sure it was wired correctly and it showed that the right LED was green and the center LED was also green and the left LED was unlit and according to the diagram on the tester this signified that the wiring was correct meaning that the hot wire was properly instralled and the neutral wire was properly installed and it was properly grounded yet the red switch light that is only supose to illuminate when the switch is on is also illuminated when the switch is in the off position and the garbage disposal does not work. Do I have a defective switch? Or am I missing something?
    Top Expert:
  • Cooper Wirin... Master
  • 45,468 Answers
You are missing something
you describe 3 led lights --2 green and one unlit then you go on about a red led light
suggest that you get in an accredited electrician to check the circuit
it is possible that you are testing with the wring tester
Posted on Mar 27, 2017
2 Suggested Answers
dgw1
  • 19 Answers
SOURCE: I just replaced a switch/outlet
First you have to make sure you have the black or hot wire hooked up to the brass screws. That should power both pieces. On the outlet portion the white or common should be on the silver screw. Then the black wire going to the light should be on the other switch screw and the bare or green should be on the green screw
Posted on Mar 03, 2011
How do I fix -no power issue on my samsung dmr78ahs dishwasher?
To eliminate a dishwasher problem, run a heavy 3 pronged extension cord from a known working outlet to the dishwasher and plug the dishwasher into the cord. If you still have no power (dishwasher is not showing any signs of life) then it is a dishwasher problem (circuit board, bad connection from dishwasher cord to dishwasher, etc).
If the dishwasher actually shows signs of life, then you may have a tripped breaker. Check the breaker to make sure it is on and that the tab is not either in the center or the off position. Also, try moving the dishwasher cord's plug from the outlet it is currently in to another outlet in the under sink area. There is a chance that the plug got switched from the normal outlet to the outlet that controls the garbage disposal, that outlet should only be hot when the disposal wall switch is flipped to the on position.
Dec 18, 2014 | Samsung DMR78AHS Builtin Dishwasher
Kenmore garbage disposal continuously running
make sure you have it plugged into the right outlet. Only one outlet out of the two is controlled by the switch. The other outlet is on all the time.
Dec 28, 2012 | Dishwashers
Circuit tester when plugged into 3 pronged plug, comes up with 2 green lights and 1 yellow light. There is no code on other side of tester to access this problem
Circuit analyzer does not show all possible problems, and tester might be defective.
Use analyzer on other outlets.
Buy another circuit analyzer.
Buy a multimeter at local hardware, and test for voltage, and continuity, and compare with known outlet that are functioning correctly.
For example outlet may be 240Volt instead of 120V.
Copy following links to see typical circuit analyzer and code:
http://waterheatertimer.org/images/Typical-circuit-analyzer-15.jpg
http://waterheatertimer.org/images/Outlet-polarity-200.jpg
May 22, 2012 | Leviton Electrical Supplies
Garbage disposal
My checklist for garbage disposals:
(1) most disposals have a little red RESET switch on the bottom. Once the impeller will turn manually, press the reset button, and you may get back full operation.
(2) 120 Volt wall switch may have burned out. They're only rated for 100,000 operations before they burn out.
(3) If the impeller is difficult to turn, you may try to use an "flywheel wrench", which is just an offset Allen wrench that fits into the bottom of the motor, and can be used to turn the flywheel manually, freeing the impeller and allowing the reset to work.
(4) The circuit breaker in the breaker panel in the basement may have tripped, cutting power to the switch controlling the garbage disposal. If tripped, turn off the switch to the disposal and reset the breaker.
(5) Disposal motor may have died.
This How-To seems like a nice one:
http://homerepair.about.com/od/plumbingrepair/ss/fix_disposal.htm
Nov 26, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Microwave has no power when plunged in
1) Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
2) Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
3) Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
4) Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Apr 04, 2011 | Maytag Microwave Ovens
When we switch on the garbage disposal, there's no sound at all..dead. Switched power cord to another outlet, plugged it in and automatically the motor turns on but the blades don't move. It doesn't...
If you plug it into the original outlet under the sink and flip the switch, nothing happens? No motor sound? And when you plug it into a different outlet, you can hear the motor, but the blades don't turn?
If this is the situation, I would guess that there's a problem with the insinkerator. Something stuck in it, or it's otherwise jammed. This could have tripped a breaker.
If the breaker failed or the circuit wasn't wired properly, this jammed condition could also have resulted in the wire at the switch or under-sink receptacle burning off of the terminals.
Turn off the circuit at the panel, double check that it's off, and remove the switch and the receptacle to see if the wires are still connected. If they've burned off, do not re-connect them. You should consult a licensed electrician to correct a hazardous situation.
Mar 17, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I just replaced a switch/outlet with a 274V and used a circuit tester and got a correct signal on the outlet circuit but the switch light remains on in both the on and off position and my garbage disposal...
Feb 28, 2011 | Cooper Wiring Devices 274V-BOX DECORATOR...
I installed a new garbage disposal. The way I connected electric to it was to just run a pigtail to a near by outlet. I put a switch between the outlet and the disposal. Whenever I try to turn it on it...
It sounds like you put in ordinary wall switch.
You use the word 'pigtail' which implies electrical knowledge, so without a photo it's hard to tell where the switch is shorting the circuit.
You need a single-pole switch with 2 screws and a ground screw.
If you use a 3-way switch, your wires are connected to dark screw and one of the brass screw
You have 2 wires running between receptacle and disposal.
The wall switch interrupts one wire. Not both wires.
So one wire from receptacle runs continuously to disposal.
The other wire is cut and one end attaches to a switch screw, the other end of the cut wire attaches on the other switch screw.
The bare ground wire connects to green screw.
Preferably the Hot wire is cut.
Nov 13, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Sink garbage disposal not working! when I switch the garbage disposal on, nothing happens!
Do you hear a humming sound when you turn it on? If so, you have a clogged disposal. Check on the bottom for the allen wrench location recessed in the middle of the disposal. Insert the proper size allen wrench and you'll be able to rotate the motor back and forth (sometimes difficult at first) and eventually loosen the clog and free up the motor. If you're able to move the shaft/motor easily in the beginning and it still doesn't work you may have a defective disposal. If you want to check more thoroughly you'll need to check to see if you have power at the disposal when you turn on the switch. Use a electrical tester that you can buy at any home improvement store to see if you have power at the disposal. If so, and the motor turns easily when you use your allen wrench, you have a defective disposal and it needs replacement.
Oct 02, 2010 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Switch will not turn on disposal
under the sink you will probably find an electrical outlet with the disposal cord plugged in. If so, plug another item into the outlet like a blow dryer to be sure you have power to the outlet. If you have no power the problem is a tripped breaker or a blown fuse. First check all of the plugs in the kitchen area including under the sink to determine if you have a ground fault circuit interrupter outlet. If you do, it may be tripped. If it is tripped simply reset it.
If you know you have power to the disposal then check to be sure no spoon or other hard object isn't in the disposal preventing it from operating. Use a flash light to check this. If there is no obstruction look on the case of the disposal for a reset button. good luck.
Jan 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Cooper Wiring Devices 274V-BOX DECORATOR SP SWITCH & GROUNDED RECEPTACLE Logo
61 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
