Question about Little Tikes Cozy Coupe
I put the front wheels on backwards on the cozy coupe and can't get the red caps off...any suggestions?
  • 3 Answers
Wedge something like a screwdriver under the cap and twist. They usually pop off with a little help.
Otherwise pliers from the top while rocking back and forth may work.
Posted on Mar 13, 2011
Thankfully there were two spare caps (I think they might be called "acorn caps") in the box (probably the manufacturers know that this is where errors occur). Okay, so I pushed a flat head screw driver under the cap and levered up a gap and then inserted an open ended spanner (wrench). This has to be a very thin wrench like the free one you often get with new kids bikes. The end was just wide enough to go around the bar over which the cap is hammered down. Then with a hammer hit the spanner as close to the bar as possible (i.e. as close to the open end of the spanner as possible). And then keep hammering. It took me about 20 minutes to remove two. If you are careful you do not damage the plastic frame. Be prepared to remove the plastic coverings of the cap once you start banging to reveal the metal cap itself. It's a worrying process with the wife wanting to know if you are succeeding and you sweating knowing that this was not the most manly thing that you have ever done messing up the building of a Cozy Coupe. You then have the child wanting to get inside. Also watch out because when the cap does come off, it does so with force. I almost took out the windscreen of the car. Good luck.
Posted on Dec 26, 2011
2 Suggested Answers
  • 4234 Answers
SOURCE: Little Tikes Cozy Coupe red plastic wheel caps
The caps are a type of "acorn nut". Check a local hardware store (not the big guys) for this type of fastener and bring the shaft with you to get the correct size. These should not cost more than about $.50 each.
Dan
Posted on Apr 09, 2009
I put the front wheels on the wrong side can I remove the axle cap and and change the wheels and put the axle cap back on
Unlikely, because the caps tend to self district instead of coming off. Replacement acorn caps should be less than a dollar at a hardware store or a lawnmower repair shop.
Mar 10, 2015 | Little Tikes Cozy Coupe
Need off put wheels wrong
how have you installed it? screw or click? either way, you can slowly and carefully remove the wheels and put it back on. If you still can't, I suggest that you call the customer service of Little Tikes and you'll find their contact numbers at http://www.littletikes.com/
Dec 25, 2013 | Little Tikes Cozy Coupe
The wheels on our Little Tikes Cozy Coupe do not turn/swivel easily
Not a solution but I wondered if you ever sorted this? I have same problem with one front wheel only... Just seems too snug a fit to the main body...? Any suggestions?
Dec 04, 2012 | Little Tikes Cozy Coupe
We just purchased the 30th Anniversary Cozy Coupe and I messed up with the right and left side front wheels, I put them in the wrong sides. I need to switch them but the red Metal Cap Nut in the front...
I have dealt with many of these metal push nuts, best thing is to break the plastic off with a needle nose or regular pliers and then that will expose the metal push nut, then you can bend that with the pliers and pull it off and swap the tires to the correct sides, keep in mind this will ruin the push nuts and new ones will need to be ordered off ebay or something similar
Aug 15, 2017 | Little Tikes Cozy Coupe 30th Anniversary...
Cosy coupe wheel.
If you have the newer style Cozy Coupe, you can purchase replacement wheels with capnut from Little Tikes.
http://www.littletikes.com/consumerservice/ReplacementParts-detail.aspx?Product_ID=2823&
Hope this helps!
The Grand Toy Wizard
www.thegrandtoywizard.com/store
Jun 26, 2009 | Little Tikes Cozy Coupe
Little tikes cozy coupe
Try replacing the screw. If you cant, get a long thin bolt and nut to replace it.
Jun 15, 2009 | Little Tikes Swing Along Castle
Dan
Apr 09, 2009 | Little Tikes Swing Along Castle
Little Tikes Cozy Coupe Logo
8,729 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
