Question about Epson Stylus Photo 1290 InkJet Printer
When printer print in economic mode the print image is not align
When I print in economic or quick mode the print image is not align (Black)
Also when I print a nozzle check below the lines the no ME290B I03193 is not aligned.
Please help
Fanie
  • Epson Master
  • 691 Answers
Run the head alignment routine from the driver. This should bring everything back to normal. You may also need to run the head cleaning cycle a couple of times.
Posted on Sep 14, 2008
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
How to set economic mode ? Lexmark X 2252
You can set some printer settings regulate ink usage (quick print mode, better or best mode) or configure it to print in black and white. Try to refer to the Lexmark X2250 User's Guide at http://bit.ly/mEpFyZ.
May 21, 2011 | Lexmark X2250 All-In-One InkJet Printer
My x3350 double prints text. It will overlay each sentence on itself. When I print worksheets on excel every other vertical line will be double-printed. I've tried to uninstall and reinstall the...
This may be a cartridge misalignment issue. First try printing with the settings changed to black and white print only. If this does not work then print in fast or draft mode (this should print in a single pass with less ink. Normal or best quality is usually done by passing the cartridges over the line twice.
Run the cartridge alignment test and see if it can be correctly aligned.
It could also be that the belt that moves the cartridge holder is loose and so two passes of the print head are misaligned. This may not be repairable (at least not economically).
Feb 20, 2011 | Lexmark X3350 All-In-One InkJet Printer
New toner cartridges, black comes out very light
check the printing mode it is econom mode or best mode try to change the resolution and see.
Jun 26, 2009 | Dell 1320c Laser Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
Deskjet 950c
Most likely your encoder has become fogged due to aerosol in the printer. You can carefully clean this following the instructions here. Be sure to heed the warnings, the encoder is fragile and can be easily damaged.
Once you have cleaned the encoder force an alignment calibration, either from the toolbox of alternately turn on the printer, then press and hold the power button, then quickly press the formfeed buttion three times, then release the power button. If the alignment fails you may need to lean the bottom of the alignment sensor, it is located in a small black package just on the lower right side of the carriage. Open the lid, allow the carriage to move to the center then clean the sensor from below with a damp q-tip.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 14, 2008 | HP DeskJet 950c InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
PRINTING PROBLEM
You printer cartridges need to be cleaned,aligned properly...printer software can do that...
PLEASE RATE ME AS ( FIXYA ) <blue boxes>............
Oct 19, 2007 | Epson Stylus D88 InkJet Photo Printer
Epson Stylus Photo 1290 InkJet Printer Logo
289 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
