Question about Dyson Ball DC24 Bagless Upright Vacuum
Brush bar bouncing when on - Dyson Ball DC24 Bagless Upright Vacuum
Beater bar isnt working I have replaced motor on dyson dc18
Be sure you are getting power to the brush bar motor. Power comes from the main switch to the brush bar switch, then to the micro switch that activates when the handle is reclined, then to the brush bar motor. Any openings in the circuit will cause the brush bar motor to not work.
Jan 23, 2017 | Dyson Vacuums
How to remove the cover on the brush bar. Sucked up wires by mistake and the brush bar won't turn
Dec 07, 2016 | Vacuums
Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
I can think of three things that could be wrong.
The easiest one is that the brush has hair and fluff wrapped around its bearing. This happened to me and was causing a burning rubber smell. Turn it over and remove the base plate. Lift the belt by putting a piece of cord under it and slide the brush out. Remove one end of the brush and slide the spindle out. Clean all the hair out and reassemble.
The internal drive belt is worn, or the nylon bush that it runs on.
The clutch is worn out.
The last two are not as easy to fix as the main drive belt is enclosed in the centre of the clutch. There are videos though that show you the process. Have a read and a watch, but try my first tip first.
  • Dyson DC25, DC29 - Resetting the brush bar (Official Dyson ... www.youtube.com/watch?v=q--faamcC7g
    • BY ASKDYSON
    • 1 MIN
    • 127K VIEWS
    2011-09-29 · Want to watch this again later? Sign in to add this video to a playlist. How to clear and reset the brush bar of your Dyson DC25 or DC29 upright ...
  • Dyson DC25 Upright Vacuum Cleaner - Support ' Dyson.com www.dyson.com/Support/dc25/DC25-ANIMAL Dyson DC25 Upright Vacuum Cleaner Support. Skip to main content X. Shop. Shop vacuums; Shop air treatment ... The Dyson Helpline is available during the following ...
  • My dyson vacuum cleaner brush will not spin. It is not the ... howtomendit.com > ... > Household Appliances, Vacuum Cleaners My dyson vacuum cleaner brush will not spin. It is not the belt. ... How can I fix my dyson dc25? The turbo button is not working... Click here for the answer:
  • Brush bar not rotating - Dyson www.dyson.co.uk/.../brush-bar-not-rotating Brush bar not rotating. ... to ensure vacuums containing Dyson Cinetic™ science maintain constant suction. ... tested at the cleaner head.
  • The Brush Won't Spin on My Dyson Vacuum Cleaner ' eHow www.ehow.com > Home > Home Appliances > Other Home Appliances 2015-06-29 · eHow; Home; Home Appliances; Other Home Appliances; ... My Dyson Vacuum Cleaner's Beater Brush Won't Spin; Dyson Vacuum Brush Roll Not... My Dyson ...
  • Dyson DC25 brush won't spin when touching the floor. If I ... www.fixya.com > Forum > Vacuums > Dyson 2016-03-18 · Dyson DC25 brush won't spin when touching the floor. If I lift it off the floor it spins, once it touches the floor it stops. Any idea what the problem is?
  • Dc25 animal. front brush not working - Fixya www.fixya.com > ... > Dyson > DC25 Animal Bagless Upright Vacuum 2012-03-29 · ... Dyson DC25 Animal Bagless ... dc25 animal. front brush not ... I have a Dyson DC-25 animal. My brush bar did not spin and has been replaced with a ...
  • Dyson DC24 Brush Bar Motor - Dyson Medic - Dyson Medic dysonmedic.co.uk/dyson-dc24-brush-bar-motor It will not spin when the ... Dyson DC24 Brush Bar ... Unit Motor Dyson DC25 Dyson DC25 beater bar Dyson DC25 brush bar Dyson DC41 Dyson DC50 Dyson Motor Dyson ...
  • DC25 brush bar not working - Dyson Spare Parts with Free ... manchestervacs.co.uk/DysonForum/index.php?topic=738.0 DC25 brush bar not working ... My brush bar stopped working on my DC25 ball the other day. ... Manchester Vacs Dyson Engineer
  • Dyson DC24 - Resetting the brush bar (Official Dyson video ... www.youtube.com/watch?v=akGLQ7UbctY
    • BY ASKDYSON
    • 2 MIN
    • 275K VIEWS
    2011-09-29 · How to clear and reset the brush bar of your Dyson DC24 upright vacuum cleaner. DC24's brush bar is engineered to shut off for protection if ...
  • Mar 18, 2016 | Dyson Vacuums
    Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
    See if the following information can help.
    CARPETS OR HARD FLOORS
    • The brush bar will always default to 'ON' (spinning) each time you switch the
    appliance 'ON' and recline it for cleaning.
    • The brush bar will not rotate when the appliance is upright.
    • To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
    - switch the appliance 'ON'
    - recline the appliance
    - press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
    • The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
    clearing obstructions'.
    • Before vacuuming your flooring, rugs and carpets, check the manufacturer's
    recommended cleaning instructions.
    • Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
    happens, we recommend vacuuming in 'hard floor' mode and consulting with
    the flooring manufacturer.
    • The brush bar on the appliance may damage some carpet types. If you are
    unsure, turn 'OFF' the brush bar.
    Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
    Why want beater bar turn on Dyson DC17?
    There are a few things it could be. Pull the handle back into the vacuuming position and turn the brush bar switch on and off while listening to see if you can hear the brush bar motor turn off and on. If you can hear the brush bar motor running it may need a new belt and/or the brush bar may be seized up.
    There is a switch by the main power switch that provides power to run the brush bar motor. There is a micro switch down in the motor area that closes the circuit to the brush bar motor when you pull the handle back. Check electrical connections and all of the above parts to determine which one or one's may be defective.
    Jul 09, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
    Why want the beater bar turn?
    Jul 09, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
    Beater bar
    It could be your brush bar is not working properly if there is debris restricting the endcaps, the brush bar motor could be defective, it could be a switch or wiring problem.
    Jun 26, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
    My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
    This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
    Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
    May 31, 2014 | Neato XV11 Vacuum
    The brush bar on my Dyson DC17 stopped turning.
    If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
    Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
    Hopping - jumping - skipping - bouncing
    It could be that you have the brush settings wrong for your carpet type. Check if the brushes are on number 3, if so, try dropping them down a notch or two and see if that does it. I think that the brushes when spinning spin towards you, so when pulling the vacuum back, the brushes are helping to drive, when pushing forward, you are pushing against the brushes. If the brushes are sticking out too far, it could cause bouncing/jumping. HTH :)
    May 23, 2007 | Kirby G6 Bagged Upright Vacuum
    Dyson Ball DC24 Bagless Upright Vacuum Logo
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
