Question about Sony Computers & Internet
My laptop screen is just a white screen when turned on
That is because the cable connecting the screen to the system board is damaged.
This can be easily fixed by either opening your system and fixing the cable, or just finding a perfect position for the screen where the cable works.
Posted on Mar 13, 2011
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
How to fix the white screen of the laptop
White screen means the hard drive did not boot. Replace the Hard Drive.
Feb 21, 2014 | Lenovo Computers & Internet
Laptop white screen
Having a laptop screen turn white is one of the most frustrating problems a user can experience since it prevents use of the laptop to find a solution.
A white laptop screen indicates a serious problem with the laptop's hardware, and no easy solution to this issue exists.
Just diagnosing this condition requires advanced computer knowledge.
Identification
With this problem, the laptop itself will power on and load the operating system as per usual, but the screen will become a complete, static white, according to LaptopRepair101.
No particular brand or make of laptop falls prey to this issue more than any other; it can happen to any laptop.
Causes
Since so many different brands and models of laptops exist, specific causes of a white screen vary from laptop to laptop.
The likely cause in most cases of a white screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard.
The issue can also reside strictly with the motherboard or the screen might contain a defect.
Considerations Users can diagnose a white screen problem by opening up the laptop display case to determine whether a loose video connection on the back of the LCD screen exists.
Reconnecting the video cable should resolve the white screen; a video cable reconnection that does not fix the white screen narrows the root cause to a problem with the motherboard or the screen.
Motherboard Problems
The only way to determine if the laptop screen turns white due to a motherboard problem is to test out a different, working LCD screen with the laptop.
This requires the user connect the inverter board--the power supply for the LCD backlight and the video cable to the test LCD.
If the test LCD works with the motherboard, then the laptop's screen needs replacing; otherwise, a new motherboard is needed because there is no way to replace an integrated graphics card on a laptop motherboard.
Prevention/Solution
Taking apart a laptop screen may make some users feel uncomfortable, so you can use an external monitor connected to the VGA port common to most laptops if the processor and hard drive still work fine. Using an external monitor requires finding the proper function key command to toggle between the LCD and external monitor.
Warning
Taking apart the LCD screen on a monitor likely voids any manufacturer's warranty.
Consider visually checking the video connection to the laptop screen as a last resort if no other viable options exists.
The service manual that came with your laptop likely offers some tips to disassembling the computer, or conditions that could void the warranty.
http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/
Jul 02, 2013 | Dell Inspiron Computers & Internet
WHITE SCREEN ON SAMSUNG LAPTOP
Prior to the Windows splash screen do you see graphical issues ( black background, white writing, or bios splash screen) if you don't then the problem is with windows and will need to be reinstalled. Samsung ship laptops with a windows cd and is a fairly basic wizard. If you don't know how to do this google is full of guides. If you however see graphical problems right from turning the laptop on then there is likely to be a hardware fault straight from the factory. Contact Samsung and they will repair / replace the laptop through warranty. I have seen several Samsung laptops brand new from the box do this and It turned out to be a hardware issue and was replaced on warranty. Good luck.
Apr 17, 2013 | Computers & Internet
I only have a white screen,connect to another moniter still no screen.
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
1-laptop-white-screen.jpg Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
For more information:
http://solvetheproblemhere.blogspot.com/2011/05/laptop-lcd-screen-turned-white.html
May 10, 2011 | Samsung N150 Notebook
Screen turn to white & cant recovery the system
I would reinstall windows sounds like the update corrupted it.
Feb 22, 2010 | ASUS Eee 4G Notebook
The display turn white >>>what can i do?
Laptop LCD screen turned completely white
It’s possible that you have to use a different key combination on your laptop but you get the idea.
I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out which one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen and the inverter board. After that you connect another working screen and test video.
The original screen is white but my test screen works normal and I can see the image. After this test I can tell that the problem must be related to the screen.
After I assembled everything back together and connected the original LCD, it’s still white.
CONCLUSION.
Jan 18, 2010 | Samsung NC10-14GW Notebook
White turns to pink on acer laptop
The problem is CCFL light bulb in the screen. It is starting to die :( Can be replaced but that is not an easy task (easier is to replace screen as new bulb comes with it)
Jan 12, 2009 | Acer Aspire 5630 Notebook
Computers & Internet Logo
65 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
