Question about Sharp Audio Players & Recorders
Sharp cd-ba1600 door won't open err 0201 displayed on screen
  • 2,071 Answers
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Posted on Aug 07, 2008
How do I open a cassette door that is stuck?
problem in belt
rotuate fly wheel door is open
Apr 28, 2014 | Sharp CD-BA250 CD Shelf System
meens fan problem ok thx nick use lens cleaning cd also ok
Feb 11, 2008 | Sharp CD-C2900 Shelf System
I have a Sharp Stereo Shelf System Model Number SC-9650. It is displaying a message i the CD player part I do not know what it means. It says M Err. I am unable to open the Cd door so I can fill it it...
I am having the same error on mine, and don't have a clue, I have looked all over and other people have the same problem but no one ever posts a solution.
Jul 24, 2011 | Sharp SC-9650 Shelf System
I have a Pentair MiniMax NT. I am getting ERR on the display but I can't seem to get the door open. I have tried turning the single screw that locks the left and right door but it won't unlock.
sometimes the door is just stuck. try pulling the door as you turn the locking screw. sometimes you need to use a flat head screw driver to help the door open as you turn the screw back and forth
Jun 11, 2011 | Pentair Minimax NT Heater
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Err message appears when CD function is used
check this link for service manual
Don't forget to rate the solution
Jan 09, 2009 | Emerson ES30 Shelf System
Cd player takes cd the releases with ERR showing on the display
open cd player.clean lens with cotten.your problem will be solved forever.had same problem.
Jul 15, 2008 | 2001 Nissan Sentra
Cd stuck err 0306 message
Since the cds are stuck inside, you need to open the unit and remove them. There are four screws on the top cover. Remove them (2 on each side) and lift the cover. You should see the cds, remove them, then plug on the unit.
Jun 09, 2008 | Sharp Multi-System Mini Component System...
Err 0305
I know this is no help, but I am haveing the exact same problem and I searched and cant find anything about how to fix the problem..I wish I knew what caused it at least
Jan 21, 2007 | Sharp CD-C606 Shelf System
137 people viewed this question
Top Sharp Audio Players & Recorders Experts
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
